Weather entities from integrations which I am using (Metno, Gismeteo, OpenWeatherMap) have forecast data.
Can anyone tell me how these entities are stored in DB?
Is there any “optimization”?
I believed that storing forecast data needs more space - so I simply excluded “weather” domain from Recorder and use template sensors for curr. values like temperature etc (which are included in Recorder).
All entities are stored the same in the database. They have 2 separate tables, one for the state, one for the attributes. Yes it will take up more space because it’s a larger set of attributes.
It might be worth noting here: Interestingly, weather forecasts are not real attributes, but provided by a separate API. So, those forecasts are not stored in the database 🤷 (see Weather Entity | Home Assistant Developer Docs). I double-checked in my database and they are not in the state_attributes table.
