Recorder ignoring excludes in configuration?
I’m trying to exclude recorder output via excludes in recorder.yaml
My recorder.yaml (I don’t have any includes):
purge_interval: 1
purge_keep_days: 4
exclude:
  domains:
    - updater
    - sun
    - group
    - mqtt
    - script
    - device_tracker
    - input_select
    - input_boolean
    - history_graph
  entities:
    - sensor.sunset
    - sensor.sunrise
    - sensor.sun
    - sensor.ha_version_current
    - sensor.uptime
    - sensor.date
    - sensor.time
However I still see: group names, input_selects etc in “Home Assistant -> History” menu.
I have appropriate entry in configuration.yaml:
recorder: !include recorder.yaml
I haven’t setup any history configuration yet.
Config check (hass --script check_config) doesn’t report any problems as well.
Any clues why it doesn’t work?
Regards,
M
PS. HASS 0.62.1
More output:
hass --script check_config --info recorder
Successful config (partial)
  recorder:
    exclude: ?
      domains: ?
        - updater
        - sun
        - group
        - mqtt
        - script
        - device_tracker
        - input_select
        - input_boolean
        - history_graph
      entities: ?
        - sensor.sunset
        - sensor.sunrise
        - sensor.sun
        - sensor.uptime
        - sensor.date
        - sensor.time
      event_types: ?
    include: ?
    purge_interval: 1
    purge_keep_days: 4
Any hints how can I troubleshoot this situation ??
Regards,
M
Did you wipe your database after excluding items?
Thank you for answer.
Yes, I called service:
recorder.purge
with service data:
{"keep_days": 0}
Any other ideas?
