humidity is reported as an attribute of the yweather weather platform. You can pull attributes into sensors using a template sensor. Then include the new sensor in your recorder settings.
If you have established a sensor for your indoor humidity from your weather platform you could try this: (replace sensor.local_humidity with what you display Yweather humidity reporting)
