Recorder MySQL error
I have installed home assistant to run in a python virtual environment on my Centos 7 server and works great.
I have MariaDB 10 already running on the server and I am trying to configure the home assistant recorder to use the MariaDB, I have created ha users/db and I have installed mysqlclient on the python virtual environment and added the following to configuration.yaml
recorder:
  db_url: mysql://hauser:hapass@localhost/homeassistant
But whenever I start home assistant I get the following recorder errors
thass[92585]: 2020-12-15 12:22:18 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: name '_mysql' is not defined (retrying in 3 seconds)
Any ideas to fix much appreciated…
Did you do what is documented here:
MariaDB and MySQL
If you are in a virtual environment, don’t forget to activate it before installing the mysqlclient Python package described below.
Yes I did, for everything that needed to be done in the virtual environment, looks like it all compiled and installed correctly, but when running up hass, the recorder is failing to find … name ‘_mysql’ is not defined …
I’m assuming its a package it can’t find external of the virtual environment but I have the mysql-client (MariaDB-client) installed
