My system will not start the recorder anymore. It throws an exception which is not very clear to me what is actually failing. log file with debug level:
2020-11-29 12:06:41 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_default_level>
2020-11-29 12:06:41 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_level>
2020-11-29 12:06:41 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2020-11-29 12:06:41 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logger>
2020-11-29 12:06:41 INFO (MainThread) [homeassistant.setup] Setting up http
2020-11-29 12:06:41 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds
2020-11-29 12:06:41 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
2020-11-29 12:06:41 INFO (MainThread) [homeassistant.setup] Setting up system_log
2020-11-29 12:06:41 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=clear>
2020-11-29 12:06:41 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=write>
2020-11-29 12:06:41 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds
2020-11-29 12:06:41 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=system_log>
2020-11-29 12:06:41 ERROR (MainThread) [homeassistant.bootstrap] Error setting up integration recorder - received exception
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/setup.py", line 64, in async_setup_component
return await task # type: ignore
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/setup.py", line 158, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/setup.py", line 343, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/requirements.py", line 74, in async_get_integration_with_requirements
await async_process_requirements(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/requirements.py", line 121, in async_process_requirements
if pkg_util.is_installed(req):
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/util/package.py", line 54, in is_installed
return version(req.project_name) in req
File "/srv/homeassistant/lib/python3.8/site-packages/pkg_resources/__init__.py", line 3078, in __contains__
return self.specifier.contains(item, prereleases=True)
File "/srv/homeassistant/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
item = parse(item)
File "/srv/homeassistant/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
return Version(version)
File "/srv/homeassistant/lib/python3.8/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
I have deleted the database and recreated it and restarted the system, but that did not help. Besides the recorder and the history HA is working fine. How to fix this?
