Hello!
I’m trying to make the history bigger, that by default stores 10 days only. In my first install years ago there was no such limit, which I really enjoyed.
In configuration.yaml I try to set it for one year with the lines:
recorder:
purge_keep_days: 365
I’m getting the following error when checking the config:
Invalid config for [recorder]: [themes] is an invalid option for [recorder]. Check: recorder->recorder->themes. (See /config/configuration.yaml, line 25).
I also tried different values and copied straight from the Integrations-Description page. No luck.
How to get it right?
Thanks for your help.
