Recorder Retention Period By Entity
True. My bad. Forgot this was a FR… :frowning:
I have half a mind to ditch some integrations and then re-add them but I don’t know if that would clear the data…
Removing entities does not delete entity history/statistics data (unless you do it manually)
This seems like a useful feature. There are many sensors that I want to retain for longer periods, like battery status, leak status, temperature, humidity.
I would also suggest the ability to toggle this at the device level, or even integration level. I have 1370 entities currently, and it would be a lot of work enabling them one by one. But of course this depends on the UI - if it allows filters & multiple selection, then it may not be as much of a problem.
Good point. If the UI could group, filter and/or sort them it would make things easier. Of course none of that can happen until the underlying database structure changes to support retention periods per entity.
In the mean time, a lot of people have found it’s easier to use include rather than exclude in their configuration for Recorder. If I knew then what I know now, I might have gone that route when setting up HA. Admittedly it’s still a very blunt instrument, and something like this FR would still be extremely helpful.
A very useful use-case for this functionality is for device_tracker/person entities: it will be possible to see a track on a map for some particular period in the past. Of course if period is defined by some “start” & “end” data, not by “hours_to_show”. Some custom map cards (like this great card) already have this method to define a period implemented.
I’d love to have retention period by entity, and also the ability to downsample it after that.
Moreover, it would be great to be able to configure include, exclude and retention periods using labels.
For example, defining a label “label for excluded entities”, associate this label to every entities you want to exclude and just configure in the recorder configuration:
recorder:
  exclude:
    label: 'label for excluded entities'
