I’d like to be able to set a Recorder keep_days value for each entity.
Background: New and non-technical users are steered toward running HA on a RPi with an SD card. Yet, if they take the defaults, every event and state change is recorded in the SQL database on the SD card, leading to a bloated database file and shortened SD card life.
Yes, I know there are lots of ways to change these defaults, including using other databases and database locations. But for most beginners, it’s a steep learning curve and this isn’t going to be high on their list - until something fails.
Not all new users have experience with database management. Forcing them to install software, download the database, run SQL commands, figure out which events and state changes they want to include or exclude, and creating the appropriate config lines is a lot to ask.
I can do all that, but even so I’m frustrated by the fact that I can specify only one retention period. There are things I want 24 hours of log data for, and others I want to keep for 7 days.
The whole recorder process seems very primitive compared to the rest of HA.
To me, the best solution would be to allow the (new) user to establish a keep_days for each entity. This should be easy to do when the entity is first defined, and wherever its properties are displayed for edit.
I see this has come up before, but didn’t get much traction. Anyone else?
