Hi there, i want to use Recorder with an existing mysql server. HA stops with:
2017-05-10 20:49:39 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named ‘MySQLdb’ (retrying in 3 seconds)
Could the mysql-client be added to the HA image?
Edit: This works with the nomal HA Dockerimage
Edit2: Same with pymysql.
Is on Task list: https://www.pivotaltracker.com/story/show/145231347
Fix with homeassistant docker 0.45
Works! Great Job.
I have this error with Hassio 1.0. The fix is supposed to work directly or we need to modify something in the config?
The db_url in the docs should work with external MySQL Server or the MariaDB addon.
I found my problem. I was using mysql+pymysql instead of mysql only. Thanks for your help guys!
