Recording stable weight from hx711
I’m looking to get a sensor that displays the weight on a platfom only if it remains the same for a period of time. This is the current code that Igot from esphome smart scale:
    name: "Smart Scale HX711 Value"
    internal: False
    filters:
      # apply auto_tare difference
      - lambda: 'return x + id(auto_tare_difference);'
      # apply rough calibration
      - calibrate_linear:
          # retrieve these values by evaluating the raw values with loads of known mass.
          # note that a bigger difference between measurements usually results in higher resolution,
          # so measure 0 Kg and the highest known mass you have (like f.ex. your own weight, measured by a normal scale with good accuracy)
          - 13120 -> 0
          - 31100 -> 8
      # map values below 0.1 to 0 (to decrease value changes due to random fluctuation)
      - lambda: |-
          if (x <= 0.1) {
            return 0.0;
          } else {
            return x;
    unit_of_measurement: kg
    accuracy_decimals: 2
    # the sensor will automatically update through the 'sensor.template.publish' call
    update_interval: never
I would like to have a separate sensor that only displays the value of “Smart Scale HX711 Value” if it has a stable weight that remains unchanged for 3 seconds. I have tried quite a few different ways and haven’t had any success.
I used a delta filter for that, with sufficiently high value.
Does it fluctuate over long periods of time for you too? Mine sees a swing of over 300g even after temperature compensation thru third to seventh degree polynomial curves.
if I could ask what are you using for the temperature compensation?
Temperature probe with voltage divider. It tracks with my other temperature sensors.
Thanks I’ve ended up using the delta and and debounce filter in a seperate sensor and it’s basically doing what I want. I haven’t been using it very long but with auto tare enabled in the esp smart scale code I am getting fairly accurate results at this stage. My use case maybe different to yours though as I want to weigh something that is stepping on and off my scale not constantly sitting on it.
Yah it’s different. I want to weigh a gas cylinder so I need it to be stable over long periods of time.
