I just updated HASSIO and after reboot I am unable to connect to HA. The WebUi comes up with connection refused, SSH says refuse to connect, and I am unable to access the samba shares. I am able to access the HASSOS via ssh using port 22222. Is there a way to get the configuration files from the docker that way or any suggestions on how to fix the installation?
I did try curl -d ‘{“version”: “0.55”}’ http://hassio/homeassistant/update from HASSOS and received Failed to connect to hassio port 80: Connection refused.
Thanks for the help in advance.
