The problem is that this element counts the time spent cumulatively at the current moment:
What I want is for it to tell me the cumulative time planned in the schedule for the entire day of the current day.
In my concrete case today, let me recover the time for the āfiltrationā subject in the schedule indicated today:
So basically currently, I do not have the forecast time which was recorded in the schedule, but āthe time spent at the moment Tā of this event.
Here, I would therefore like it to be indicated ā12Hā (that it calculates the difference between the start and end of āfiltrationā during the day, here start 3h to end 5h = 2 and from start 10h to end 20h = 10, so total time=12h).
Yes, just make sure to set it up with triggers that make sense for your needs. As configured above it will only run at the start of each day. If you add or remove events from the calendar during the day that need to be accounted for, you can use a Time Pattern or Calendar Event trigger.
