Recreated original pre-2022.11 theme and some other options
Based on the work from @frenck, I have created some variations of his “outline” theme.
First of all, due to the replies in the Blog post to the 2022.11.0 relese, I’ve recreated the Original Theme from HomeAssistant:
First Theme Name:
grafik
  • Border-Radius: 4px
  • Shadow
  • Light & Dark mode
    grafik
    grafik
Second Theme Name:
grafik
This does recreate the “default” outline-Theme from @frenck,
  • Boder Radius: 4px
  • Removing the default Shadow from the Cards
  • Light & Dark mode
    grafik
    grafik
Third Theme Name:
grafik
  • Border-Radius: 0px
  • No Shadow
  • Light & Dark mode:
    grafik
    grafik
Fourth Theme Name:
grafik
  • Default Shadow
  • Light & Dark mode
    grafik
    grafik
This theme-pack can be downloaded from my git: (until now it is not yet in HACS…)
ToDo:
Recreate default shadows in Dark-Mode… (if dark mode had such)
Hmm, I was pretty sure that before 2022.11 we had borders set to 0? I have to admit I really dislike the new interface, could you also add an option to make it look like on the screen below? (from around April 2022)
This was so clean and tidy :slight_smile:
I’ll give it a try :slight_smile:
Since I never used the dark mode, I was not sure if it had some borders or not… just used the defaults I’ve found so far…
should now be available on github :slight_smile:
border-pixel-width set to 0px for dark and light mode…
on light mode, it can’t be seen very clearly, because of the shadow… that’s why it was not directly visible to me :slight_smile:
grafik
