I get this error in my log 11 times in a row every 9 seconds. This is obviously filling up my log quickly.
Does anyone know what might be causing it, and more importantly, how to fix it? It obviously seems like some error with my LG soundbar (I have LG ThinQ set up for my Dryer and the soundbar has Google Cast [I tried removing this integration no luck]).
2020-05-20 10:49:42 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 284, in async_update_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 314, in _async_write_ha_state
attr = self.capability_attributes
File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 784, in capability_attributes
source_list = self.source_list
File "/usr/src/homeassistant/homeassistant/components/lg_soundbar/media_player.py", line 167, in source_list
sources.append(temescal.functions[function])
IndexError: list index out of range
@Hass10 ,
I am having the same issues you described… last night I had 1147 related errors.
I first noticed this trouble in March 2022, On a daily basis I have been searching for someone that knows how to fix this problem. Can you help me?
2022-03-13 12:46:25 WARNING (MainThread) [alexapy.alexalogin] No access token found; falling back to credential login instead of oauth.
2022-03-13 12:46:26 WARNING (MainThread) [alexapy.alexawebsocket] mac_dms not detected; websocket likely won't connect
2022-04-27 10:18:38 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport for binary_sensor.kasa_smart_plug_150 to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
2022-04-27 10:53:33 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from ec2-18-210-7-77.compute-1.amazonaws.com (18.210.7.77). (python-urllib3/1.26.6)
I have thousand plus more examples… Same thing . Any ideas?
Just having a read of your specific logs, it seems like an issue with your oauth login details. Try logging into Alexa with the login details you provided to Home Assistant? Did you change them recently? If so, update them.
