Recurring problem with the Z-Wave thermostat
I have 5 Danfoss 014G0013 thermostats and I have a problem with one of them. This problem occurs when the Home Assistant does not function for some time (power failure or update to new version). Thermostat disappears from HA and its node is visible under another name. Only remove it from the Z-Wave network, reset it to factory settings and add it again to the network works. And so on average every 2 weeks. Can anyone tell me what to do about it?
HA log when thermostat disappears:
17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227769362}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818517}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818533}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818549}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818565}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818581}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818597}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818613}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818628}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594227818641}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594236977156}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594228768769}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594228785156}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594228785169}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594228785185}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237222915}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237222931}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237222947}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237222963}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237222979}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237255687}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237255703}) on node 11 17-04-23 08:03:54 WARNING (Dummy-14) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594237255719}) on node 11
After node change name:
I’ve got the same issue since version 0.55 but for any device in the network.
I removed write access to zwcfg_0x#####.xml so a restart recreates the devices, but this behavior is far from being okay.
Did you find something to fix the issue for you?
From 2-3 months I have any problems with the Z-Wave network. I don’t know if it’s Home Assistant fixes or the upgrade Python to 3.6 has helped.
