Red flag in working Script
I am on 2026.4.1 and just noticed something in a script that may have been introduced in an earlier update. It seems to be a UI thing and the script runs fine as it always has.
I noticed this red flag:-
which relates to the following YAML:-
  - action: media_player.volume_set
      entity_id: "{{ mplayer }}"
      volume_level: 0
mplayer is a variable I calculate, it works perfectly and as far as I recall, caused no red flags when I first created the script some months ago as this:-
so no errors showing there and as I said, it works fine. As does this later action:-
   - action: media_player.play_media
      media:
        media_content_id: "{{ station }}"
        media_content_type: radio
which produces no red flags:-
Screenshot 2026-04-05 at 09.53.24
It just looks to me like the UI is slightly out of step with the ability to template the entity_id here, which works but the UI doesn’t seem to know this and I’m pretty sure there was no red flag when setting up this script, so something seems a bit mixed up.
This example is a combination of old and new syntax.
      volume_level: 0
This is fully old syntax:
  - service: media_player.volume_set
      volume_level: 0
This is fully new syntax:
      volume_level: 0
The old syntax (and combinations of old and new) continue to be supported but the UI is designed to direct you to use the new syntax (i.e. “No target set”).
As for “new” syntax, it’s been the standard for several years now. Anyone creating a new script/automation, or modifying an old one, should adopt the “new” syntax.
Brilliant. Thanks @123 . That explains it.
Found a couple of those and corrected them, so I’ll watch out for that in the future.
You’re welcome!
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which indicates to others that the topic has been solved. This helps other users find answers to similar questions.
Marked as solution. Apologies for making you remind me. :slightly_smiling_face:
