Hello, I’m setting up a Node-RED flow for my HASSIO to notify me of new Reddit posts through my mobile devices due to the current IFTTT situation. I have it all setup and have got (node-red-contrib-node-reddit) & (node-red-contrib-pushover) connected and working almost flawlessly, the only flaw is that the format that Pushover shows is very very raw and was wondering if anyone knew a better way to format the two together by any chance?
FLOW:
Reddit - Pushover
So, it works… It just looks like this on my mobile devices.
Ideally I think it would be nice to have the Pushover notification of the Reddit post look like: [Title] [Subject] instead of this large wall. Any help is appreciated!
EDIT:
jcostello93 of node-red-contrib-node-reddit has helped me, what you need to do is add a function node between them and insert
msg.payload = msg.payload.title;
return msg;
Note: You can also create a Change function and it does the same thing, however I think with a straight function we’ll have more we can do with a single node.
For anyone reading this I recommend setting these up for maximum savings
r/GameDeals
r/BuildAPCSales
r/ConsoleDeals
r/FREE
r/FreeEBOOKS
r/giveaways
r/NintendoSwitchDeals
r/FreeGamesOnSteam
r/GunDeals
EDIT 2:
Alright, I have gotten this even better than I ever thought it could be thanks to jcostello93 from the node-red-contrib-node-reddit project and TheWAPMop from the discord.
[{"id":"c25a0d1.83aa5f","type":"tab","label":"Reddit Nodes","disabled":false,"info":""},{"id":"d50336cd.9b6608","type":"stream","z":"c25a0d1.83aa5f","name":"","reddit":"","kind":"submissions","subreddit":"GameDeals","filter":"inbox","markedAsRead":false,"timeout":"","pollTime":"","x":130,"y":160,"wires":[["4db71c66.73c5d4"]]},{"id":"4db71c66.73c5d4","type":"function","z":"c25a0d1.83aa5f","name":"","func":"msg.payload = msg.payload.title + \" https://www.reddit.com\" + msg.payload.permalink;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":320,"y":160,"wires":[["c343b449.7d9d78"]]},{"id":"c343b449.7d9d78","type":"pushover","z":"c25a0d1.83aa5f","name":"","device":"","title":"New Post: r/GameDeals","priority":0,"sound":"cashregister","url":"","url_title":"","html":false,"x":550,"y":160,"wires":[]}]
is the flow.
