Hello. I wiped a device thinking it was going to be discovered again. The device appears active along with the others but the integration does not appear. Is there a way for me to discover it again? The only other thing I have left is to remove it again and re-install it manually. In order not to disarm the sonoff again, they come up with something. Thank you very much
How can you remove it if it has not been discovered?
This is what I usually do:
- remove the integration.
- restart
- add the integration again, manually if it has not been discovered
I have problems with the device, a basic sonoff. In principle it works well and therefore eliminates it. You can also make sure that it is configured at the same time and that it is not known at this time. What are the plants that are drilled and manually powered by USB to dig for what they are reconciled? Thank you
Eliminate, the device and I want to create it with the same number. It does not work, sigue sin reconocierlo. This hice is eliminated using another name to be able to reconstitute. Some archive is not eliminated and it has no register that allows it to be reconstructed as a new device. It looks like it is recognizing a new device. Do you need to manually dig in USB to recognize it?
When referring to eliminate the integration and eliminate ESPHOME or the device. Reincarnation Integration, Borre the device the new grave by UART and also the reconstruction
Function. Aggregating the device by the ip with the integration.
