I just want to reduce the size of my Dashboard cards by reducing the text size and line spacing’s from header and body.
I started to do this on ‘Entity-List’ and thought that would be easy but it seems not to be.
I suppose the only ways this can be done is by using card_mod or creating a new theme
but i am not able to find the correct styles for this.
Any hints or solutions are very welcome!
What is the best approach to reduce the size?
Maybe someone knows a size-reduced theme?
Thanks for your reply!
I am sorry but i don’t understand the “creating a custom template” approach for this.
Can you give me more details or an example?
I will try that.
It looks like you are also using a smaller font size.
Have you done this by changing the theme or also via card-mod?
Can you also post your solution for this?
The words I used are a bit confusing since the word template in HA is associated with the jinja scripting. I more or less meant something like layout-card but I cannot find the thing I once found but never used myself eventually.
As you can see the spacing for the lines on the “Rollo” card are bigger than on the other cards
but i can’t figure out how to reduce the size/padding of the cover controls, any tips for this?
Also i would like to reduce the size of the toggle switches on the “Licht” card, any tips for this?
