Reduce impact of DSMR on home-assistant_v2.db
My home-assistant_v2.db grows to over 1 GB ! I think it mainly has to do with dsmr reading ( like continous voltage)
Can I keep the dsmr (smart meter) intergsated, but remove eveything from the longer term database?
And, if so, how? ( Since I tried to exclude it using
> exclude: -dsmr in the config)
Thanks!
Alexander.
You have multiple options.
  • Exclude all (or some) DSMR sensors from the recorder component
  • Exclude some components from being added to the entity registry in the first place
  • Condense sensors with the throttle component
