I have a Jasco Zigbee Metering outlet in my office that reports power consumption very frequently. See log snapshot below. With zwave you typically have configuration options to adjust the thresholds and reporting frequency but I can’t find anything similar for this device.
I’ve been digging around in the “Manage Clusters” section of the device as I am guessing I should be able to find what the reporting is set at, and possibly override it. Anyone know how to do it?
I have the same device and not found a way to override it - did you?
Instead I purge the history of the more “noisy” sensors to limit the amount of days that are kept. Another approach might be to create a separate template sensor from the noisy one that updates less frequently - Change (slow down) interval update template sensor - #3 by PeteRage (and remove the original sensor from recorder)
That doesn’t fix the fact that your zigbee network is being swamped by messages.
The proper solution is to apply the setting on the device. Have a look at my post here and the clusters mentioned in the posts above it - hopefully you’ll manage to find something which fixes it.
