I currently have this automoation setup to notify me via pushover when my WeMo motion detects movement when nobody is home.
automation 3:
alias: Monitor Home
- platform: state
entity_id: binary_sensor.hallway_motion
to: 'on'
condition:
condition: state
entity_id: group.all_devices
state: not_home
- service: notify.notifyap
message: Motion Detected at Home
This works exactly as I expect it to do so. However, is there a way to only notify me at a maximum rate… I.e. a maximum of once per min. At the moment, if it detects movement I would get a rush of a bout 5 or 6 notifications within a few seconds.
The issue I’m currently facing, is the location is not updating quick enough to know that i’m at home. I’m in the process of resolving this with an iBeacon, but would be good to know if the above can be done.
My not be the smoothest way to do it but a template condition to only trigger if the automation was not run in the past X seconds may work. Can’t find the thread where someone helped me with this code but it should be a cookbook to get you going.
Test replace the automation name with your automation ie monitor home and test it in the dev tool. From there you can trigger the automation and see how it changes. It should let the automation trigger on true and not trigger on false.
I do this with a rain notification I’m using. Like @silvrr says, mine also may not be the smoothest way but it works. I just toggle the automation, add a delay and then toggle it back on again.
# Rain Alert
- alias: 'Raining'
platform: state
entity_id: sensor.dark_sky_precip_intensity
- service: tts.google_say
entity_id: media_player.living_room_home
data_template:
message: 'Excuse me Robert, but is currently {{ states.sensor.dark_sky_precip.state }}ing and it is {{ states.sensor.dark_sky_temperature.state | int }}degrees outside. Forecast says {{ states.sensor.dark_sky_minutely_summary.state }}.'
cache: false
- service: automation.turn_off
entity_id: automation.raining
- delay: 00:30:00
- service: automation.turn_on
