After setting up several devices running tasmota I found I had the same config repeated many times. A way to minimise this is to use yamls Anchor and Alias pattern.
In my switches.yaml I had entries like this:
- platform: mqtt
state_topic: "stat/pond_pumps/POWER"
command_topic: "cmnd/pond_pumps/POWER"
availability_topic: "tele/pond_pumps/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
Everything from qos
down was identical for each device. All of this repeated config can be defined as an anchor with &
and injected where we want it with <<: *
The one hurdle we have is getting around homeassistants yaml validation. The neatest way I found to do this was to add an empty template switch with a spurious object to hold all the repeated config. This does trigger a slightly alarming log entry âNo switches loadedâ, but it is just because of the empty template switch, all switches are still loaded as normal, so I can live with that.
After this my switches.yaml looks like this:
- platform: template # anchor data trojan horse
switches: {}
tasmota: &tasmota_mqtt
platform: mqtt
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: false
- <<: *tasmota_mqtt
This is identical to the original config once loaded. However now additional device only requires 5 lines instead of 10 and the âdefaultsâ can be overidden at will.
Because I am using common name formats I am trying to find a way to use pyyamls !join operator to do away with the need for the topic config as well, but it doesnât seem possible to pass the name in.
