I am still new to Home Assistant so forgive me if this is a dumb question. My configuration.yaml file contains the below code to make a virtual switch called “test” from a template and also my AArlo camera configuration which is a HACS integration. My log file is complaining about there being 2 switch: keywords in my configuration.yaml file. If I comment out the code so there is only 1 instance of the keyword switch:, then the log warning goes away. Is it possible to have the keyword switch: used more than once in the configuration.yaml file? If not, then how can I make a virtual switch but still have my camera configuration statements.
# Template for Virtual Switch Example
switch:
switches:
test:
value_template: "{{ is_state('some_state_condition', 'off') }}"
turn_off:
service: switch.turn_off
entity_id: switch.test
turn_on:
service: switch.turn_on
#Arlo Cameras
aarlo:
username: xxxxxxxxxxxxxxx
password: xxxxxxxxxxxxxxx
refresh_devices_every: 2
stream_timeout: 120
reconnect_every: 90
- platform: aarlo
monitored_conditions:
- battery_level
- signal_strength
light:
- platform: aarlo
switch:
- platform: aarlo
siren: True
siren_volume: 8
siren_duration: 15
binary_sensor:
- platform: aarlo
- motion
