Hi, I’m new to esphome/HA. I’ve got a atc_mithermometer temperature sensor defined in one yaml, and I’d like to use it to control a switch attached to a fan heater defined in another yaml. I’m using the Thermostat Climate Controller, but I can’t figure out what to fill in for the “sensor” to reference the temperature sensor.
ESP32 with bluetooth extender to read temperature
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
networks:
- ssid: "main_iot"
password: !secret wifi_main_iot_pass
manual_ip:
static_ip: 192.168.1.143
gateway: 192.168.1.1
subnet: 255.255.255.0
captive_portal:
logger:
api:
ota:
esp32_ble_tracker:
- platform: atc_mithermometer
mac_address: "A4:C1:38:13:95:9E"
temperature:
name: "Art Room Temperature"
humidity:
name: "Art Room Humidity"
battery_level:
name: "Art Room Battery-Level"
battery_voltage:
name: "Art Room Battery-Voltage"
# there are several more here, but I removed them for brevity
Fan Heater yaml
esphome:
platform: ESP8266
board: esp01_1m
wifi:
networks:
- ssid: "main_iot"
captive_portal:
logger:
api:
climate:
- platform: thermostat
name: "Thermostat Climate Controller"
sensor: what do I put here??????????????????????????????????????????????
default_target_temperature_low: 25 °C
min_heating_off_time: 30s
min_heating_run_time: 30s
min_idle_time: 30s
heat_action:
- switch.turn_on: relay
idle_action:
- switch.turn_off: relay
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Heater Switch Button"
on_press:
- switch.toggle: relay
- platform: status
name: "Heater Switch Status"
switch:
- platform: gpio
name: "Heater Switch Relay"
pin: GPIO12
