Reference to lists of hardware manufacturers of home automation products?
Relatively new to home automation, I find myself reinventing the wheel every time I start looking a product to do X. For instance, I want a motion sensor for our 2-light walk in closet. I start looking at bulb manufacturers, then motion sensors, then I see that Wyze has a light bulb socket that powers their cameras… and down the rabbit hole I go. Forgetting for the moment that I’ll want it to integrate with my home-asssitant install, I’m all over the place.
So, I’m hoping there is a master list or database you all might recommend that helps looking for products and mfrs in different home automation categories. So that I could use it to narrow down what I’m looking for.
Suggestions? References?
Thanks!
If you use Zigbee, this has already helped me: https://zigbee.blakadder.com/
Thanks @pwgdrx I don’t use Zigbee, but that’s a good reference.
I don’t want cause any raised torches, but I’m just starting with all this, I’m still using all Wifi and haven’t jumped into either Zwave or Zigbee - don’t know which road to travel. Still hoping that HA allows that to be a bit of a non-issue.
Thanks for the reference, I’ll start there!
And for z-wave: https://devices.zwave-js.io/ or https://www.z-wave.com/shop-z-wave-smart-home-products
