I am wanting to compare the temperatures between two different devices i.e. the temperature in my roof which is easily found by “sensor.roof_temperature” and the current set temperature of my air conditioner.
The problem I am having is my air conditioner has an inside and outside temperature sensor but I can’t work out how to reference the current set temperature.
When looking at the Developer Tools, I can see the following:
hvac_modes:
- fan_only
- dry
- cool
- heat
- heat_cool
- 'off'
min_temp: 7
max_temp: 35
target_temp_step: 1
fan_modes:
- Auto
- Silence
- '1'
- '2'
- '3'
- '4'
- '5'
preset_modes:
- none
- away
- eco
- boost
swing_modes:
- 'Off'
- Vertical
- Horizontal
- 3D
current_temperature: 23
temperature: 18
fan_mode: '2'
hvac_action: cooling
preset_mode: none
swing_mode: 3D
friendly_name: Living Area
supported_features: 57
The automation wizard only lets me refer to the “inside temperature” and not the set “temperature”.
alias: "HRV: Turn off when Aircon turned on"
description: ""
- platform: state
entity_id:
- climate.living_area
- platform: state
entity_id:
- climate.upstairs
condition:
- condition: or
conditions:
- condition: and
conditions:
- condition: state
entity_id: climate.living_area
state: cool
- condition: numeric_state
entity_id: sensor.living_area_inside_temperature
below: sensor.roof_temperature
- condition: and
conditions:
- condition: state
entity_id: climate.upstairs
state: cool
entity_id: sensor.upstairs_inside_temperature
enabled: true
- condition: or
conditions:
- condition: and
conditions:
- condition: state
state: heat
above: sensor.roof_temperature
- condition: and
conditions:
- condition: state
state: heat
enabled: false
- service: switch.turn_off
data: {}
entity_id: switch.hrv
mode: single
