This is my first post here. I have a Qubino ZMNHJD1 with the Qubino Temperature sensor and it seems that the module do not send automatically the value of the temperature when it changes to the controller.
As it is not automatically updated, I tried to create a HA automation but I encounter a weird issue that I do not understand.
The first execution of the refresh_value automation, I can see that the controller is queried and air temperature value is correctly updated. But it only happens once. The following executions say error:type. Here is a more detailed of what I have done and what log was saying :
YAML
description: ''
alias: Chauffage - SDB - Test
trigger: []
condition: []
- device_id: b6470540e148755505c5ad6a1c3a3888
domain: zwave_js
entity_id: sensor.sdb_seche_serviette_air_temperature
type: refresh_value
mode: single
16h26 : First automation run
Automation config
description: ''
trigger: []
condition: []
domain: zwave_js
type: refresh_value
mode: single
Run trace
Executed: 28 janvier 2022, 16:26:29
z-wavejs2mqtt debug log
2022-01-28 16:26:29.189 INFO ZWAVE: Node 46: metadata updated: 49-0-Air temperature
2022-01-28 16:26:29.192 INFO ZWAVE: Node 46: value updated: 49-0-Air temperature 19.3 => 19.2
HA system log
(empty)
16h28 : 2nd automation run
Run trace
Executed: 28 janvier 2022, 16:28:30
Error: 'type'
(empty)
HA system log
Logger: homeassistant.components.automation.nouvelle_automatisation_2
Source: components/zwave_js/device_action.py:243
Integration: Automatisation (documentation, issues)
First occurred: 16:28:30 (2 occurrences)
Last logged: 16:28:30
Chauffage - SDB - Test: Error executing script. Unexpected error for device at pos 1: 'type'
While executing automation automation.nouvelle_automatisation_2
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 381, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 595, in _async_device_step
await platform.async_call_action_from_config(
File "/usr/src/homeassistant/homeassistant/components/zwave_js/device_action.py", line 243, in async_call_action_from_config
action_type = service = config.pop(CONF_TYPE)
KeyError: 'type'
16h30 : Third automation run
same as 2nd
16h33 : Automation recreation (I just deleted the action then save then add again the action) + First automation run
Run trace
Executed: 28 janvier 2022, 16:33:20
2022-01-28 16:33:20.887 INFO ZWAVE: Node 46: metadata updated: 49-0-Air temperature
2022-01-28 16:33:20.893 INFO ZWAVE: Node 46: value updated: 49-0-Air temperature 19.2 => 19.3
HA system log
(empty)
16h37 : 2nd automation run
Run trace
Executed: 28 janvier 2022, 16:37:05
Error: 'type'
(empty)
HA system log
First occurred: 16:37:05 (2 occurrences)
Last logged: 16:37:05
KeyError: 'type'
Complete HA system log
2022-01-28 16:37:05 ERROR (MainThread) [homeassistant.components.automation.nouvelle_automatisation_2] Chauffage - SDB - Test: Error executing script. Unexpected error for device at pos 1: 'type'
KeyError: 'type'
2022-01-28 16:37:05 ERROR (MainThread) [homeassistant.components.automation.nouvelle_automatisation_2] While executing automation automation.nouvelle_automatisation_2
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 508, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1260, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 363, in async_run
await self._async_step(log_exceptions=False)
KeyError: 'type'
