Hi all. I’ve had some trouble with Home Assistant on a Raspberry PI 3B and just received a new ODroid N2+ with Home Assistant preinstalled on eMMC. I have it powered up and connected to my network via ethernet. I can’t connect to it via a browser and get a “refused to connect” error regardless of whether I try homeassistant.local:8123 or IP:8123.
- The device shows on my network and I’m able to ping the IP address.
- I connected a monitor to the ODroid and Home Assistant is running and shows the expected IP as well as Home Assistant url.
- I tried some steps found on these forums, such as checking the time (date time is accurate)
- I’ve checked firewalls and other network settings (Omada) and have found nothing that should block access
I’m stumped, frustrated and dying to get Home Assistant up and running again. Any and all help appreciated.
