visata
November 4, 2020, 12:55pm
1
I’m looking to buy these spotlights YLTS04YL and a ceiling light YLXD50YL.
I’d be looking to integrate everything into HA. I did some research and it seems everyone favors the integration either via Conbee ii or zigbee2mqtt.
I checked Conbee ii and zigbee2mqtt supported devices list and it seems neither of them are supported?
https://phoscon.de/en/conbee2/compatible
Does it mean there is no way to do the integration into HA? Should I buy Yeelight Smart Mesh Gateway Hub - YLWG01YL instead and wait till someone does the integration into HA?
ConBee and ZigBee2MQTT is used for integrating ZigBee devices. But as far as I can see from the product description, these are bluetooth bulbs not ZigBee.
visata
November 4, 2020, 1:16pm
3
Thanks for your reply.
Is that possible to do the integration with HA via manufacturer’s hub/gateway? This one YLWG01YL is supposed to work with spotlights.
Or I should be looking for ZigBee based spotlights, ceiling light for an easy integration with HA?
Unfortunately I don’t know, no experience with yeelight.
ZigBee based lights are definitely easy to integrate into HA, but I fon’t know if it is easier thann the yeelight ones.
visata
November 4, 2020, 2:03pm
6
I did some digging around and it seems these lights might be integrated into HA using ESPHome?
