Started to play around with the HA Modbus integration to read data from my Stiebel Eltron Heat Pump. The example is as easy as it can be:
modbus:
- name: stiebel_eltron_hub
type: tcp
host: 192.168.x.x
port: 502
sensors:
- name: se_aussentemperatur
unit_of_measurement: °C
slave: 1
scale: 0.1
input_type: input
address: 506
- name: se_wwisttemperatur
slave: 1
scale: 0.1
input_type: input
address: 521
Everything work as expected but what I’m observing consistently is a register lag by 1. I.e. If I want to read Modbus register 507 I have to use address: 506. This is confirmed by e.g. qModMaster where I get the value of register 507 when requesting 507.
Is there any parameter in the Modbus Integration I missed out which might cause the register lag?
Thanks for your comments and ideas!
Tiro
