cmoers
(Cedric Moers)
April 8, 2020, 7:48am
1
Hi all,
Lately my home assistant setup stops about twice a week, so I tried to delve into the logs to see what went wrong. I notice that there is a recurring ‘out of memory exception’ that takes place at the time of the crash/stop.
Unfortunately I’m not very familiar with those loggings and linux/raspbian. I was hoping someone could point me to a possible the source of the exception and maybe a solution.
It is clear that this has to do with a memory limit, but I do not know if this is a software limit or a (reconfigurable) hardware limit. And if so, if it is possible to increase this limit.
Due to this exception, the docker container stops and restarting the container does not work without a full reboot of the raspberry pi.
I run a Home Assistant/Hass.IO container in docker on a Raspberry Pi 4B (1GB RAM), using an 500GB SSD to boot from. I also expose a shared folder with movies, from which I stream to a chromecast using VLC on smartphone or watch on Kodi (on tablet or Android TV)
I will include two log snapshots from the time of the stop below.
This is a snapshot of free memory after a stop without a reboot of the memory:
total used free shared buff/cache available
Mem: 924Mi 408Mi 269Mi 76Mi 246Mi 374Mi
Swap: 99Mi 99Mi 0B
cmoers
(Cedric Moers)
April 8, 2020, 7:56am
2
Stop of April 8
Apr 8 06:55:45 raspberrypi systemd[1]: Starting Daily apt download activities...
Apr 8 06:55:49 raspberrypi dhclient[11129]: DHCPDISCOVER on vethe6fe7a5 to 255.255.255.255 port 67 interval 10
Apr 8 06:55:52 raspberrypi kernel: [425946.654959] python3 invoked oom-killer: gfp_mask=0x7080c0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), nodemask=(null), order=1, oom_score_adj=0
Apr 8 06:55:52 raspberrypi kernel: [425946.654964] python3 cpuset=b7660dfa813c1dab26610eac4dca19b82c1edd9459a46568e2a7aecf73e85603 mems_allowed=0
Apr 8 06:55:52 raspberrypi kernel: [425946.654977] CPU: 3 PID: 6413 Comm: python3 Tainted: G C 4.19.97-v7l+ #1294
Apr 8 06:55:52 raspberrypi kernel: [425946.654981] Hardware name: BCM2835
Apr 8 06:55:52 raspberrypi kernel: [425946.655000] [<c0212e04>] (unwind_backtrace) from [<c020d5e0>] (show_stack+0x20/0x24)
Apr 8 06:55:52 raspberrypi kernel: [425946.655010] [<c020d5e0>] (show_stack) from [<c09b15c8>] (dump_stack+0xe0/0x124)
Apr 8 06:55:52 raspberrypi kernel: [425946.655021] [<c09b15c8>] (dump_stack) from [<c0363e28>] (dump_header+0x80/0x250)
Apr 8 06:55:52 raspberrypi kernel: [425946.655029] [<c0363e28>] (dump_header) from [<c0363190>] (oom_kill_process+0x358/0x3a8)
Apr 8 06:55:52 raspberrypi kernel: [425946.655036] [<c0363190>] (oom_kill_process) from [<c0363ac0>] (out_of_memory+0x134/0x37c)
Apr 8 06:55:52 raspberrypi kernel: [425946.655043] [<c0363ac0>] (out_of_memory) from [<c0369ea4>] (__alloc_pages_nodemask+0xfc0/0x1180)
Apr 8 06:55:52 raspberrypi kernel: [425946.655050] [<c0369ea4>] (__alloc_pages_nodemask) from [<c021f8c0>] (copy_process.part.5+0x1f4/0x1ad4)
Apr 8 06:55:52 raspberrypi kernel: [425946.655057] [<c021f8c0>] (copy_process.part.5) from [<c0221368>] (_do_fork+0xd8/0x438)
Apr 8 06:55:52 raspberrypi kernel: [425946.655064] [<c0221368>] (_do_fork) from [<c0221774>] (sys_fork+0x34/0x3c)
Apr 8 06:55:52 raspberrypi kernel: [425946.655070] [<c0221774>] (sys_fork) from [<c0201000>] (ret_fast_syscall+0x0/0x28)
Apr 8 06:55:52 raspberrypi kernel: [425946.655074] Exception stack(0xef4b3fa8 to 0xef4b3ff0)
Apr 8 06:55:52 raspberrypi kernel: [425946.655079] 3fa0: 00000000 b4cfd848 00000000 b6f8253c b4cfd848 b2322ce0
Apr 8 06:55:52 raspberrypi kernel: [425946.655084] 3fc0: 00000000 b4cfd848 b6eeaf10 00000002 b69bbf1c ad74a5c0 b6eeaf10 00000000
Apr 8 06:55:52 raspberrypi kernel: [425946.655088] 3fe0: b2322ce0 b4cfd848 b6f5f6b1 b6f5f6b8
Apr 8 06:55:52 raspberrypi kernel: [425946.655092] Mem-Info:
Apr 8 06:55:52 raspberrypi kernel: [425946.655102] active_anon:46168 inactive_anon:67176 isolated_anon:0
Apr 8 06:55:52 raspberrypi kernel: [425946.655102] active_file:9648 inactive_file:6681 isolated_file:0
Apr 8 06:55:52 raspberrypi kernel: [425946.655102] unevictable:4 dirty:0 writeback:0 unstable:0
Apr 8 06:55:52 raspberrypi kernel: [425946.655102] slab_reclaimable:9869 slab_unreclaimable:20172
Apr 8 06:55:52 raspberrypi kernel: [425946.655102] mapped:14623 shmem:21089 pagetables:2003 bounce:0
Apr 8 06:55:52 raspberrypi kernel: [425946.655102] free:66265 free_pcp:8 free_cma:61604
Apr 8 06:55:52 raspberrypi kernel: [425946.655110] Node 0 active_anon:184672kB inactive_anon:268704kB active_file:38592kB inactive_file:26724kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:58492kB dirty:0kB writeback:0kB shmem:84356kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
Apr 8 06:55:52 raspberrypi kernel: [425946.655119] DMA free:263976kB min:16384kB low:20480kB high:24576kB active_anon:130036kB inactive_anon:211700kB active_file:672kB inactive_file:1072kB unevictable:0kB writepending:0kB present:786432kB managed:762316kB mlocked:0kB kernel_stack:4792kB pagetables:5476kB bounce:0kB free_pcp:32kB local_pcp:0kB free_cma:246416kB
Apr 8 06:55:52 raspberrypi kernel: [425946.655123] lowmem_reserve[]: 0 0 180 180
Apr 8 06:55:52 raspberrypi kernel: [425946.655136] HighMem free:1084kB min:180kB low:1168kB high:2156kB active_anon:54636kB inactive_anon:57004kB active_file:38296kB inactive_file:26048kB unevictable:16kB writepending:0kB present:184320kB managed:184320kB mlocked:16kB kernel_stack:0kB pagetables:2536kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Apr 8 06:55:52 raspberrypi kernel: [425946.655140] lowmem_reserve[]: 0 0 0 0
Apr 8 06:55:52 raspberrypi kernel: [425946.655148] DMA: 584*4kB (UMEHC) 314*8kB (UMEHC) 672*16kB (UMHC) 217*32kB (MEHC) 32*64kB (HC) 11*128kB (C) 1*256kB (C) 1*512kB (C) 0*1024kB 0*2048kB 58*4096kB (C) = 264336kB
Apr 8 06:55:52 raspberrypi kernel: [425946.655176] HighMem: 49*4kB (UM) 63*8kB (UM) 16*16kB (UM) 4*32kB (U) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1084kB
Apr 8 06:55:52 raspberrypi kernel: [425946.655199] 37915 total pagecache pages
Apr 8 06:55:52 raspberrypi kernel: [425946.655204] 566 pages in swap cache
Apr 8 06:55:52 raspberrypi kernel: [425946.655208] Swap cache stats: add 56921, delete 56355, find 378275/385957
Apr 8 06:55:52 raspberrypi kernel: [425946.655212] Free swap = 0kB
Apr 8 06:55:52 raspberrypi kernel: [425946.655216] Total swap = 102396kB
Apr 8 06:55:52 raspberrypi kernel: [425946.655219] 242688 pages RAM
Apr 8 06:55:52 raspberrypi kernel: [425946.655223] 46080 pages HighMem/MovableOnly
Apr 8 06:55:52 raspberrypi kernel: [425946.655227] 6029 pages reserved
Apr 8 06:55:52 raspberrypi kernel: [425946.655230] 65536 pages cma reserved
Apr 8 06:55:52 raspberrypi kernel: [425946.655234] Tasks state (memory values in pages):
Apr 8 06:55:52 raspberrypi kernel: [425946.655238] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
Apr 8 06:55:52 raspberrypi kernel: [425946.655251] [ 106] 0 106 8898 1620 192512 22 0 systemd-journal
Apr 8 06:55:52 raspberrypi kernel: [425946.655257] [ 141] 0 141 4621 210 45056 32 -1000 systemd-udevd
Apr 8 06:55:52 raspberrypi kernel: [425946.655264] [ 276] 100 276 5603 274 61440 47 0 systemd-timesyn
Apr 8 06:55:52 raspberrypi kernel: [425946.655270] [ 319] 108 319 1562 455 40960 20 0 avahi-daemon
Apr 8 06:55:52 raspberrypi kernel: [425946.655275] [ 320] 0 320 13662 211 81920 81 0 ModemManager
Apr 8 06:55:52 raspberrypi kernel: [425946.655280] [ 325] 0 325 16957 1121 90112 532 0 udisksd
Apr 8 06:55:52 raspberrypi kernel: [425946.655286] [ 326] 104 326 1754 506 36864 61 -900 dbus-daemon
Apr 8 06:55:52 raspberrypi kernel: [425946.655291] [ 332] 0 332 6378 503 53248 20 0 rsyslogd
Apr 8 06:55:52 raspberrypi kernel: [425946.655296] [ 334] 0 334 3287 483 53248 49 0 systemd-logind
Apr 8 06:55:52 raspberrypi kernel: [425946.655302] [ 335] 108 335 1443 28 36864 35 0 avahi-daemon
Apr 8 06:55:52 raspberrypi kernel: [425946.655307] [ 337] 0 337 1987 142 40960 13 0 cron
Apr 8 06:55:52 raspberrypi kernel: [425946.655312] [ 338] 0 338 2716 299 45056 47 0 wpa_supplicant
Apr 8 06:55:52 raspberrypi kernel: [425946.655318] [ 343] 0 343 923 56 36864 26 0 alsactl
Apr 8 06:55:52 raspberrypi kernel: [425946.655323] [ 346] 65534 346 1080 58 32768 17 0 thd
Apr 8 06:55:52 raspberrypi kernel: [425946.655329] [ 351] 0 351 17178 1666 110592 57 0 NetworkManager
Apr 8 06:55:52 raspberrypi kernel: [425946.655334] [ 357] 0 357 6914 172 40960 7 0 rngd
Apr 8 06:55:52 raspberrypi kernel: [425946.655339] [ 374] 0 374 907 459 32768 118 0 dhcpcd
Apr 8 06:55:52 raspberrypi kernel: [425946.655345] [ 430] 0 430 10479 569 77824 291 0 polkitd
Apr 8 06:55:52 raspberrypi kernel: [425946.655350] [ 464] 0 464 2157 0 40960 56 0 vncserver-x11-s
Apr 8 06:55:52 raspberrypi kernel: [425946.655355] [ 468] 0 468 11068 1166 98304 201 0 unattended-upgr
Apr 8 06:55:52 raspberrypi kernel: [425946.655361] [ 472] 0 472 9828 834 90112 124 0 vncserver-x11-c
Apr 8 06:55:52 raspberrypi kernel: [425946.655367] [ 473] 0 473 258472 4850 225280 173 0 containerd
Apr 8 06:55:52 raspberrypi kernel: [425946.655372] [ 479] 0 479 10027 203 69632 0 0 lightdm
Apr 8 06:55:52 raspberrypi kernel: [425946.655377] [ 481] 0 481 2681 73 45056 71 -1000 sshd
Apr 8 06:55:52 raspberrypi kernel: [425946.655383] [ 486] 0 486 2776 659 45056 1 0 wpa_supplicant
Apr 8 06:55:52 raspberrypi kernel: [425946.655388] [ 524] 0 524 42659 5545 290816 0 0 Xorg
Apr 8 06:55:52 raspberrypi kernel: [425946.655394] [ 541] 0 541 2870 143 45056 13 0 vncagent
Apr 8 06:55:52 raspberrypi kernel: [425946.655399] [ 555] 0 555 8133 282 61440 8 0 lightdm
Apr 8 06:55:52 raspberrypi kernel: [425946.655404] [ 563] 1000 563 3735 202 53248 156 0 systemd
Apr 8 06:55:52 raspberrypi kernel: [425946.655410] [ 566] 1000 566 4217 187 57344 233 0 (sd-pam)
Apr 8 06:55:52 raspberrypi kernel: [425946.655415] [ 577] 1000 577 14085 177 98304 232 0 lxsession
Apr 8 06:55:52 raspberrypi kernel: [425946.655421] [ 586] 1000 586 1664 240 36864 49 0 dbus-daemon
Apr 8 06:55:52 raspberrypi kernel: [425946.655426] [ 612] 1000 612 1130 10 32768 62 0 ssh-agent
Apr 8 06:55:52 raspberrypi kernel: [425946.655432] [ 622] 1000 622 13158 247 73728 64 0 gvfsd
Apr 8 06:55:52 raspberrypi kernel: [425946.655437] [ 627] 1000 627 14193 16 86016 152 0 gvfsd-fuse
Apr 8 06:55:52 raspberrypi kernel: [425946.655442] [ 637] 1000 637 15910 647 102400 235 0 openbox
Apr 8 06:55:52 raspberrypi kernel: [425946.655448] [ 639] 1000 639 11784 125 98304 181 0 lxpolkit
Apr 8 06:55:52 raspberrypi kernel: [425946.655453] [ 643] 1000 643 40715 3810 192512 559 0 lxpanel
Apr 8 06:55:52 raspberrypi kernel: [425946.655459] [ 644] 1000 644 32162 3306 155648 233 0 pcmanfm
Apr 8 06:55:52 raspberrypi kernel: [425946.655464] [ 650] 1000 650 1130 13 32768 59 0 ssh-agent
Apr 8 06:55:52 raspberrypi kernel: [425946.655469] [ 652] 1000 652 485 0 32768 17 0 cmstart.sh
Apr 8 06:55:52 raspberrypi kernel: [425946.655475] [ 662] 1000 662 1218 0 32768 68 0 xcompmgr
Apr 8 06:55:52 raspberrypi kernel: [425946.655480] [ 686] 1000 686 7176 53 57344 151 0 menu-cached
Apr 8 06:55:52 raspberrypi kernel: [425946.655486] [ 690] 1000 690 24507 605 114688 152 0 gvfs-udisks2-vo
Apr 8 06:55:52 raspberrypi kernel: [425946.655491] [ 694] 1000 694 14007 37 81920 216 0 gvfs-afc-volume
Apr 8 06:55:52 raspberrypi kernel: [425946.655496] [ 699] 1000 699 10032 22 69632 127 0 gvfs-mtp-volume
Apr 8 06:55:52 raspberrypi kernel: [425946.655502] [ 703] 1000 703 10026 75 73728 84 0 gvfs-goa-volume
Apr 8 06:55:52 raspberrypi kernel: [425946.655507] [ 707] 1000 707 10424 208 65536 22 0 gvfs-gphoto2-vo
Apr 8 06:55:52 raspberrypi kernel: [425946.655513] [ 732] 1000 732 13811 302 81920 87 0 gvfsd-trash
Apr 8 06:55:52 raspberrypi kernel: [425946.655518] [ 753] 1000 753 8030 378 81920 294 0 vncserverui
Apr 8 06:55:52 raspberrypi kernel: [425946.655524] [ 767] 1000 767 7939 475 81920 234 0 vncserverui
Apr 8 06:55:52 raspberrypi kernel: [425946.655529] [ 768] 1000 768 7776 686 65536 3 0 gvfsd-metadata
Apr 8 06:55:52 raspberrypi kernel: [425946.655535] [ 782] 0 782 1978 119 36864 171 0 dhclient
Apr 8 06:55:52 raspberrypi kernel: [425946.655540] [ 842] 0 842 258135 5686 327680 4518 -500 dockerd
Apr 8 06:55:52 raspberrypi kernel: [425946.655545] [ 845] 0 845 9250 1792 94208 266 0 nmbd
Apr 8 06:55:52 raspberrypi kernel: [425946.655551] [ 852] 0 852 1405 0 36864 102 0 login
Apr 8 06:55:52 raspberrypi kernel: [425946.655556] [ 904] 0 904 12091 512 118784 303 0 smbd
Apr 8 06:55:52 raspberrypi kernel: [425946.655561] [ 930] 0 930 535 19 28672 13 0 hciattach
Apr 8 06:55:52 raspberrypi kernel: [425946.655567] [ 935] 0 935 11357 244 110592 330 0 smbd-notifyd
Apr 8 06:55:52 raspberrypi kernel: [425946.655572] [ 936] 0 936 11358 259 110592 327 0 cleanupd
Apr 8 06:55:52 raspberrypi kernel: [425946.655577] [ 937] 0 937 2452 210 36864 51 0 bluetoothd
Apr 8 06:55:52 raspberrypi kernel: [425946.655583] [ 938] 0 938 12088 253 110592 331 0 lpqd
Apr 8 06:55:52 raspberrypi kernel: [425946.655588] [ 940] 0 940 6677 0 57344 101 0 bluealsa
Apr 8 06:55:52 raspberrypi kernel: [425946.655594] [ 1472] 1000 1472 2123 29 45056 214 0 bash
Apr 8 06:55:52 raspberrypi kernel: [425946.655599] [ 1597] 0 1597 485 12 32768 7 0 hassio-supervis
Apr 8 06:55:52 raspberrypi kernel: [425946.655605] [ 1624] 0 1624 236379 2319 212992 3253 0 docker
Apr 8 06:55:52 raspberrypi kernel: [425946.655610] [ 1665] 0 1665 199794 398 40960 15 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655616] [ 1692] 0 1692 49 0 24576 1 0 s6-svscan
Apr 8 06:55:52 raspberrypi kernel: [425946.655621] [ 1840] 0 1840 50 0 20480 3 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655626] [ 1987] 0 1987 493 143 32768 25 -1000 udevd
Apr 8 06:55:52 raspberrypi kernel: [425946.655632] [ 2075] 0 2075 50 1 20480 0 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655637] [ 2077] 0 2077 37928 9190 290816 808 0 python3
Apr 8 06:55:52 raspberrypi kernel: [425946.655643] [ 2196] 0 2196 1821 4 36864 72 0 socat
Apr 8 06:55:52 raspberrypi kernel: [425946.655648] [ 2223] 0 2223 199970 493 40960 0 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655654] [ 2242] 0 2242 199794 360 40960 44 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655659] [ 2280] 0 2280 199794 380 36864 49 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655665] [ 2302] 0 2302 49 0 20480 4 0 s6-svscan
Apr 8 06:55:52 raspberrypi kernel: [425946.655670] [ 2317] 0 2317 49 0 24576 5 0 s6-svscan
Apr 8 06:55:52 raspberrypi kernel: [425946.655675] [ 2337] 0 2337 49 1 24576 0 0 s6-svscan
Apr 8 06:55:52 raspberrypi kernel: [425946.655681] [ 2526] 0 2526 50 1 24576 0 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655686] [ 2850] 0 2850 45 0 16384 3 0 foreground
Apr 8 06:55:52 raspberrypi kernel: [425946.655692] [ 2851] 0 2851 45 2 16384 0 0 foreground
Apr 8 06:55:52 raspberrypi kernel: [425946.655697] [ 2855] 0 2855 50 0 20480 3 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655702] [ 2856] 0 2856 50 1 20480 0 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655708] [ 2904] 0 2904 44 1 16384 0 0 foreground
Apr 8 06:55:52 raspberrypi kernel: [425946.655714] [ 2908] 0 2908 44 1 16384 0 0 foreground
Apr 8 06:55:52 raspberrypi kernel: [425946.655719] [ 3192] 0 3192 324 1 20480 0 0 sleep
Apr 8 06:55:52 raspberrypi kernel: [425946.655724] [ 3227] 0 3227 207525 1414 122880 172 0 coredns
Apr 8 06:55:52 raspberrypi kernel: [425946.655730] [ 3260] 0 3260 1489 95 32768 106 -1000 udevd
Apr 8 06:55:52 raspberrypi kernel: [425946.655735] [ 3283] 0 3283 50 0 20480 3 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655741] [ 3286] 0 3286 20032 162 53248 328 0 pulseaudio
Apr 8 06:55:52 raspberrypi kernel: [425946.655746] [ 3342] 0 3342 199970 368 45056 60 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655752] [ 3383] 0 3383 215523 10 90112 303 -500 docker-proxy
Apr 8 06:55:52 raspberrypi kernel: [425946.655757] [ 3393] 0 3393 49 0 24576 4 0 s6-svscan
Apr 8 06:55:52 raspberrypi kernel: [425946.655763] [ 3404] 0 3404 215523 57 86016 303 -500 docker-proxy
Apr 8 06:55:52 raspberrypi kernel: [425946.655768] [ 3423] 0 3423 215523 45 98304 292 -500 docker-proxy
Apr 8 06:55:52 raspberrypi kernel: [425946.655773] [ 3439] 0 3439 213282 0 86016 273 -500 docker-proxy
Apr 8 06:55:52 raspberrypi kernel: [425946.655779] [ 3453] 0 3453 199794 393 36864 57 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655784] [ 3471] 0 3471 179 10 24576 3 0 docker-init
Apr 8 06:55:52 raspberrypi kernel: [425946.655789] [ 3605] 0 3605 50 0 20480 2 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655795] [ 3756] 0 3756 50 0 24576 2 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655800] [ 3759] 0 3759 1685 102 36864 186 0 bash
Apr 8 06:55:52 raspberrypi kernel: [425946.655806] [ 3801] 0 3801 1438 89 32768 22 0 mysqld_safe
Apr 8 06:55:52 raspberrypi kernel: [425946.655811] [ 3864] 0 3864 679 13 24576 271 0 bash
Apr 8 06:55:52 raspberrypi kernel: [425946.655816] [ 4076] 0 4076 823 12 28672 44 0 socat
Apr 8 06:55:52 raspberrypi kernel: [425946.655821] [ 4077] 0 4077 4216 1063 61440 2401 0 mosquitto
Apr 8 06:55:52 raspberrypi kernel: [425946.655827] [ 4739] 0 4739 199794 385 36864 62 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655832] [ 4757] 0 4757 199794 220 40960 47 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655838] [ 4772] 0 4772 179 9 24576 4 0 docker-init
Apr 8 06:55:52 raspberrypi kernel: [425946.655843] [ 4798] 0 4798 179 13 24576 0 0 docker-init
Apr 8 06:55:52 raspberrypi kernel: [425946.655848] [ 4824] 0 4824 49 0 24576 10 0 s6-svscan
Apr 8 06:55:52 raspberrypi kernel: [425946.655854] [ 4876] 0 4876 50 0 24576 3 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655859] [ 5229] 0 5229 4336 993 61440 1448 0 hass-configurat
Apr 8 06:55:52 raspberrypi kernel: [425946.655865] [ 5338] 0 5338 50 0 24576 3 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655870] [ 5339] 0 5339 50 0 20480 3 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655875] [ 5343] 0 5343 13406 2174 81920 1775 0 esphome
Apr 8 06:55:52 raspberrypi kernel: [425946.655881] [ 5345] 0 5345 1464 23 36864 99 0 nginx
Apr 8 06:55:52 raspberrypi kernel: [425946.655886] [ 5399] 0 5399 1511 80 32768 83 0 nginx
Apr 8 06:55:52 raspberrypi kernel: [425946.655891] [ 5997] 0 5997 199794 422 45056 20 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655897] [ 6014] 0 6014 49 0 24576 8 0 s6-svscan
Apr 8 06:55:52 raspberrypi kernel: [425946.655902] [ 6052] 0 6052 50 0 24576 2 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655908] [ 6199] 0 6199 2483 45 32768 67 -1000 udevd
Apr 8 06:55:52 raspberrypi kernel: [425946.655914] [ 6384] 0 6384 50 0 24576 2 0 s6-supervise
Apr 8 06:55:52 raspberrypi kernel: [425946.655919] [ 6385] 0 6385 42635 17040 360448 534 0 python3
Apr 8 06:55:52 raspberrypi kernel: [425946.655925] [ 10648] 1000 10648 6499 117 45056 95 0 dconf-service
Apr 8 06:55:52 raspberrypi kernel: [425946.655930] [ 10717] 1000 10717 36974 2611 192512 245 0 mousepad
Apr 8 06:55:52 raspberrypi kernel: [425946.655936] [ 12944] 1000 12944 16128 367 94208 12 0 gvfsd-network
Apr 8 06:55:52 raspberrypi kernel: [425946.655941] [ 12971] 1000 12971 15900 450 98304 25 0 gvfsd-dnssd
Apr 8 06:55:52 raspberrypi kernel: [425946.655948] [ 13588] 0 13588 208608 293 65536 0 -500 docker-proxy
Apr 8 06:55:52 raspberrypi kernel: [425946.655953] [ 13604] 0 13604 199794 417 40960 10 -999 containerd-shim
Apr 8 06:55:52 raspberrypi kernel: [425946.655959] [ 13621] 0 13621 203301 1882 86016 21 0 portainer
Apr 8 06:55:52 raspberrypi kernel: [425946.655964] [ 26003] 0 26003 1866 108 32768 0 0 git
Apr 8 06:55:52 raspberrypi kernel: [425946.655970] [ 1038] 0 1038 80720 19876 335872 0 0 mysqld
Apr 8 06:55:52 raspberrypi kernel: [425946.655978] [ 11129] 0 11129 1978 859 45056 0 0 dhclient
Apr 8 06:55:52 raspberrypi kernel: [425946.655983] [ 11166] 0 11166 485 94 28672 0 0 apt.systemd.dai
Apr 8 06:55:52 raspberrypi kernel: [425946.655988] [ 11170] 0 11170 485 281 28672 0 0 apt.systemd.dai
Apr 8 06:55:52 raspberrypi kernel: [425946.655994] [ 11178] 0 11178 12981 3395 131072 0 0 apt-get
Apr 8 06:55:52 raspberrypi kernel: [425946.655999] Out of memory: Kill process 1038 (mysqld) score 76 or sacrifice child
Apr 8 06:55:52 raspberrypi kernel: [425946.656074] Killed process 1038 (mysqld) total-vm:322880kB, anon-rss:78928kB, file-rss:576kB, shmem-rss:0kB
Apr 8 06:55:52 raspberrypi kernel: [425946.678025] oom_reaper: reaped process 1038 (mysqld), now anon-rss:0kB, file-rss:40kB, shmem-rss:0kB
Apr 8 06:55:59 raspberrypi dhclient[11129]: DHCPDISCOVER on vethe6fe7a5 to 255.255.255.255 port 67 interval 10
Apr 8 06:56:00 raspberrypi dbus-daemon[326]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.586' (uid=0 pid=11405 comm="/usr/bin/gdbus call --system --dest org.freedeskto")
Apr 8 06:56:00 raspberrypi systemd[1]: Starting PackageKit Daemon...
Apr 8 06:56:00 raspberrypi PackageKit: daemon start
Apr 8 06:56:00 raspberrypi dbus-daemon[326]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Apr 8 06:56:00 raspberrypi systemd[1]: Started PackageKit Daemon.
cmoers
(Cedric Moers)
April 8, 2020, 7:58am
3
Previous log continued:
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <warn> [1586321762.5289] dhcp4 (vethe6fe7a5): request timed out
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.5323] dhcp4 (vethe6fe7a5): state changed unknown -> timeout
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.5726] dhcp4 (vethe6fe7a5): canceled DHCP transaction, DHCP client pid 11129
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.5734] dhcp4 (vethe6fe7a5): state changed timeout -> done
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.5762] device (vethe6fe7a5): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <warn> [1586321762.5792] device (vethe6fe7a5): Activation: failed for connection 'Wired connection 4'
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.5822] device (vethe6fe7a5): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Withdrawing address record for fe80::b13:840f:6a5c:84d0 on vethe6fe7a5.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Leaving mDNS multicast group on interface vethe6fe7a5.IPv6 with address fe80::b13:840f:6a5c:84d0.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Interface vethe6fe7a5.IPv6 no longer relevant for mDNS.
Apr 8 06:56:02 raspberrypi dhcpcd[374]: vethe6fe7a5: pid 351 deleted route to 169.254.0.0/16
Apr 8 06:56:02 raspberrypi kernel: [425957.181833] dhcpcd invoked oom-killer: gfp_mask=0x7080c0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), nodemask=(null), order=1, oom_score_adj=0
Apr 8 06:56:02 raspberrypi kernel: [425957.181841] dhcpcd cpuset=/ mems_allowed=0
Apr 8 06:56:02 raspberrypi kernel: [425957.181854] CPU: 2 PID: 374 Comm: dhcpcd Tainted: G C 4.19.97-v7l+ #1294
Apr 8 06:56:02 raspberrypi kernel: [425957.181858] Hardware name: BCM2835
Apr 8 06:56:02 raspberrypi kernel: [425957.181876] [<c0212e04>] (unwind_backtrace) from [<c020d5e0>] (show_stack+0x20/0x24)
Apr 8 06:56:02 raspberrypi kernel: [425957.181887] [<c020d5e0>] (show_stack) from [<c09b15c8>] (dump_stack+0xe0/0x124)
Apr 8 06:56:02 raspberrypi kernel: [425957.181898] [<c09b15c8>] (dump_stack) from [<c0363e28>] (dump_header+0x80/0x250)
Apr 8 06:56:02 raspberrypi kernel: [425957.181906] [<c0363e28>] (dump_header) from [<c0363190>] (oom_kill_process+0x358/0x3a8)
Apr 8 06:56:02 raspberrypi kernel: [425957.181912] [<c0363190>] (oom_kill_process) from [<c0363ac0>] (out_of_memory+0x134/0x37c)
Apr 8 06:56:02 raspberrypi kernel: [425957.181919] [<c0363ac0>] (out_of_memory) from [<c0369ea4>] (__alloc_pages_nodemask+0xfc0/0x1180)
Apr 8 06:56:02 raspberrypi kernel: [425957.181927] [<c0369ea4>] (__alloc_pages_nodemask) from [<c021f8c0>] (copy_process.part.5+0x1f4/0x1ad4)
Apr 8 06:56:02 raspberrypi kernel: [425957.181935] [<c021f8c0>] (copy_process.part.5) from [<c0221368>] (_do_fork+0xd8/0x438)
Apr 8 06:56:02 raspberrypi kernel: [425957.181941] [<c0221368>] (_do_fork) from [<c02217ec>] (sys_clone+0x34/0x3c)
Apr 8 06:56:02 raspberrypi kernel: [425957.181947] [<c02217ec>] (sys_clone) from [<c0201000>] (ret_fast_syscall+0x0/0x28)
Apr 8 06:56:02 raspberrypi kernel: [425957.181951] Exception stack(0xdca95fa8 to 0xdca95ff0)
Apr 8 06:56:02 raspberrypi kernel: [425957.181956] 5fa0: 0005dca0 00000002 00004111 b6f3fff8 ffffffff 00000000
Apr 8 06:56:02 raspberrypi kernel: [425957.181961] 5fc0: 0005dca0 00000002 b6ecf000 00000078 b6f37000 bed7e3e8 bed7e648 00045bac
Apr 8 06:56:02 raspberrypi kernel: [425957.181965] 5fe0: 00004111 bed7e340 b6e48c80 b6e5c558
Apr 8 06:56:02 raspberrypi kernel: [425957.181969] Mem-Info:
Apr 8 06:56:02 raspberrypi kernel: [425957.181980] active_anon:44606 inactive_anon:66738 isolated_anon:0
Apr 8 06:56:02 raspberrypi kernel: [425957.181980] active_file:10603 inactive_file:7686 isolated_file:0
Apr 8 06:56:02 raspberrypi kernel: [425957.181980] unevictable:4 dirty:4 writeback:0 unstable:0
Apr 8 06:56:02 raspberrypi kernel: [425957.181980] slab_reclaimable:10005 slab_unreclaimable:20414
Apr 8 06:56:02 raspberrypi kernel: [425957.181980] mapped:13633 shmem:22037 pagetables:1998 bounce:0
Apr 8 06:56:02 raspberrypi kernel: [425957.181980] free:65869 free_pcp:16 free_cma:61604
Apr 8 06:56:02 raspberrypi kernel: [425957.181989] Node 0 active_anon:178424kB inactive_anon:266952kB active_file:42412kB inactive_file:30744kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:54532kB dirty:16kB writeback:0kB shmem:88148kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
Apr 8 06:56:02 raspberrypi kernel: [425957.181998] DMA free:261944kB min:16384kB low:20480kB high:24576kB active_anon:128180kB inactive_anon:213696kB active_file:656kB inactive_file:344kB unevictable:0kB writepending:0kB present:786432kB managed:762316kB mlocked:0kB kernel_stack:4832kB pagetables:5412kB bounce:0kB free_pcp:8kB local_pcp:4kB free_cma:246416kB
Apr 8 06:56:02 raspberrypi kernel: [425957.182001] lowmem_reserve[]: 0 0 180 180
Apr 8 06:56:02 raspberrypi kernel: [425957.182015] HighMem free:1532kB min:180kB low:1168kB high:2156kB active_anon:50044kB inactive_anon:52720kB active_file:41912kB inactive_file:29916kB unevictable:16kB writepending:16kB present:184320kB managed:184320kB mlocked:16kB kernel_stack:0kB pagetables:2580kB bounce:0kB free_pcp:56kB local_pcp:8kB free_cma:0kB
Apr 8 06:56:02 raspberrypi kernel: [425957.182019] lowmem_reserve[]: 0 0 0 0
Apr 8 06:56:02 raspberrypi kernel: [425957.182027] DMA: 585*4kB (UMEHC) 334*8kB (UMEHC) 541*16kB (UMEHC) 218*32kB (UMHC) 32*64kB (HC) 11*128kB (C) 1*256kB (C) 1*512kB (C) 0*1024kB 0*2048kB 58*4096kB (C) = 262436kB
Apr 8 06:56:02 raspberrypi kernel: [425957.182056] HighMem: 92*4kB (UM) 82*8kB (UM) 15*16kB (UM) 3*32kB (U) 1*64kB (U) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1424kB
Apr 8 06:56:02 raspberrypi kernel: [425957.182079] 40865 total pagecache pages
Apr 8 06:56:02 raspberrypi kernel: [425957.182084] 565 pages in swap cache
Apr 8 06:56:02 raspberrypi kernel: [425957.182088] Swap cache stats: add 56925, delete 56360, find 378278/385962
Apr 8 06:56:02 raspberrypi kernel: [425957.182092] Free swap = 0kB
Apr 8 06:56:02 raspberrypi kernel: [425957.182095] Total swap = 102396kB
Apr 8 06:56:02 raspberrypi kernel: [425957.182099] 242688 pages RAM
Apr 8 06:56:02 raspberrypi kernel: [425957.182103] 46080 pages HighMem/MovableOnly
Apr 8 06:56:02 raspberrypi kernel: [425957.182107] 6029 pages reserved
Apr 8 06:56:02 raspberrypi kernel: [425957.182110] 65536 pages cma reserved
Apr 8 06:56:02 raspberrypi kernel: [425957.182114] Tasks state (memory values in pages):
Apr 8 06:56:02 raspberrypi kernel: [425957.182118] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
Apr 8 06:56:02 raspberrypi kernel: [425957.182133] [ 106] 0 106 10380 1617 204800 24 0 systemd-journal
Apr 8 06:56:02 raspberrypi kernel: [425957.182139] [ 141] 0 141 4621 210 45056 32 -1000 systemd-udevd
Apr 8 06:56:02 raspberrypi kernel: [425957.182148] [ 276] 100 276 5603 251 61440 47 0 systemd-timesyn
Apr 8 06:56:02 raspberrypi kernel: [425957.182154] [ 319] 108 319 1562 451 40960 20 0 avahi-daemon
Apr 8 06:56:02 raspberrypi kernel: [425957.182159] [ 320] 0 320 13662 211 81920 81 0 ModemManager
Apr 8 06:56:02 raspberrypi kernel: [425957.182165] [ 325] 0 325 16957 1120 90112 532 0 udisksd
Apr 8 06:56:02 raspberrypi kernel: [425957.182171] [ 326] 104 326 1754 493 36864 61 -900 dbus-daemon
Apr 8 06:56:02 raspberrypi kernel: [425957.182176] [ 332] 0 332 6378 523 53248 20 0 rsyslogd
Apr 8 06:56:02 raspberrypi kernel: [425957.182181] [ 334] 0 334 3287 419 53248 49 0 systemd-logind
Apr 8 06:56:02 raspberrypi kernel: [425957.182187] [ 335] 108 335 1443 28 36864 35 0 avahi-daemon
Apr 8 06:56:02 raspberrypi kernel: [425957.182192] [ 337] 0 337 1987 137 40960 13 0 cron
Apr 8 06:56:02 raspberrypi kernel: [425957.182197] [ 338] 0 338 2716 274 45056 47 0 wpa_supplicant
Apr 8 06:56:02 raspberrypi kernel: [425957.182203] [ 343] 0 343 923 56 36864 26 0 alsactl
Apr 8 06:56:02 raspberrypi kernel: [425957.182208] [ 346] 65534 346 1080 58 32768 17 0 thd
Apr 8 06:56:02 raspberrypi kernel: [425957.182214] [ 351] 0 351 17178 1607 110592 57 0 NetworkManager
Apr 8 06:56:02 raspberrypi kernel: [425957.182219] [ 357] 0 357 6914 172 40960 7 0 rngd
Apr 8 06:56:02 raspberrypi kernel: [425957.182225] [ 374] 0 374 916 441 32768 118 0 dhcpcd
Apr 8 06:56:02 raspberrypi kernel: [425957.182230] [ 430] 0 430 10479 553 77824 291 0 polkitd
Apr 8 06:56:02 raspberrypi kernel: [425957.182236] [ 464] 0 464 2157 0 40960 56 0 vncserver-x11-s
Apr 8 06:56:02 raspberrypi kernel: [425957.182241] [ 468] 0 468 11068 1166 98304 201 0 unattended-upgr
Apr 8 06:56:02 raspberrypi kernel: [425957.182246] [ 472] 0 472 9828 790 90112 124 0 vncserver-x11-c
Apr 8 06:56:02 raspberrypi kernel: [425957.182252] [ 473] 0 473 258472 4785 225280 173 0 containerd
Apr 8 06:56:02 raspberrypi kernel: [425957.182257] [ 479] 0 479 10027 203 69632 0 0 lightdm
Apr 8 06:56:02 raspberrypi kernel: [425957.182263] [ 481] 0 481 2681 73 45056 71 -1000 sshd
Apr 8 06:56:02 raspberrypi kernel: [425957.182268] [ 486] 0 486 2776 555 45056 1 0 wpa_supplicant
Apr 8 06:56:02 raspberrypi kernel: [425957.182273] [ 524] 0 524 42671 5322 290816 0 0 Xorg
Apr 8 06:56:02 raspberrypi kernel: [425957.182279] [ 541] 0 541 2870 143 45056 13 0 vncagent
Apr 8 06:56:02 raspberrypi kernel: [425957.182284] [ 555] 0 555 8133 280 61440 8 0 lightdm
Apr 8 06:56:02 raspberrypi kernel: [425957.182290] [ 563] 1000 563 3735 202 53248 156 0 systemd
Apr 8 06:56:02 raspberrypi kernel: [425957.182295] [ 566] 1000 566 4217 187 57344 233 0 (sd-pam)
Apr 8 06:56:02 raspberrypi kernel: [425957.182300] [ 577] 1000 577 14085 177 98304 232 0 lxsession
Apr 8 06:56:02 raspberrypi kernel: [425957.182306] [ 586] 1000 586 1664 240 36864 49 0 dbus-daemon
Apr 8 06:56:02 raspberrypi kernel: [425957.182311] [ 612] 1000 612 1130 10 32768 62 0 ssh-agent
Apr 8 06:56:02 raspberrypi kernel: [425957.182317] [ 622] 1000 622 13158 247 73728 64 0 gvfsd
Apr 8 06:56:02 raspberrypi kernel: [425957.182322] [ 627] 1000 627 14193 16 86016 152 0 gvfsd-fuse
Apr 8 06:56:02 raspberrypi kernel: [425957.182328] [ 637] 1000 637 15910 647 102400 235 0 openbox
Apr 8 06:56:02 raspberrypi kernel: [425957.182333] [ 639] 1000 639 11784 125 98304 181 0 lxpolkit
Apr 8 06:56:02 raspberrypi kernel: [425957.182339] [ 643] 1000 643 40715 3587 192512 559 0 lxpanel
Apr 8 06:56:02 raspberrypi kernel: [425957.182344] [ 644] 1000 644 32162 3150 155648 233 0 pcmanfm
Apr 8 06:56:02 raspberrypi kernel: [425957.182349] [ 650] 1000 650 1130 13 32768 59 0 ssh-agent
Apr 8 06:56:02 raspberrypi kernel: [425957.182355] [ 652] 1000 652 485 0 32768 17 0 cmstart.sh
Apr 8 06:56:02 raspberrypi kernel: [425957.182360] [ 662] 1000 662 1218 0 32768 68 0 xcompmgr
Apr 8 06:56:02 raspberrypi kernel: [425957.182365] [ 686] 1000 686 7176 53 57344 151 0 menu-cached
Apr 8 06:56:02 raspberrypi kernel: [425957.182371] [ 690] 1000 690 24507 604 114688 152 0 gvfs-udisks2-vo
Apr 8 06:56:02 raspberrypi kernel: [425957.182376] [ 694] 1000 694 14007 37 81920 216 0 gvfs-afc-volume
Apr 8 06:56:02 raspberrypi kernel: [425957.182381] [ 699] 1000 699 10032 22 69632 127 0 gvfs-mtp-volume
Apr 8 06:56:02 raspberrypi kernel: [425957.182387] [ 703] 1000 703 10026 75 73728 84 0 gvfs-goa-volume
Apr 8 06:56:02 raspberrypi kernel: [425957.182392] [ 707] 1000 707 10424 208 65536 22 0 gvfs-gphoto2-vo
Apr 8 06:56:02 raspberrypi kernel: [425957.182397] [ 732] 1000 732 13811 302 81920 87 0 gvfsd-trash
Apr 8 06:56:02 raspberrypi kernel: [425957.182402] [ 753] 1000 753 8030 378 81920 294 0 vncserverui
Apr 8 06:56:02 raspberrypi kernel: [425957.182407] [ 767] 1000 767 7939 473 81920 234 0 vncserverui
Apr 8 06:56:02 raspberrypi kernel: [425957.182413] [ 768] 1000 768 7776 638 65536 3 0 gvfsd-metadata
Apr 8 06:56:02 raspberrypi kernel: [425957.182420] [ 782] 0 782 1978 116 36864 171 0 dhclient
Apr 8 06:56:02 raspberrypi kernel: [425957.182425] [ 842] 0 842 258135 5471 327680 4518 -500 dockerd
Apr 8 06:56:02 raspberrypi kernel: [425957.182430] [ 845] 0 845 9250 1749 94208 266 0 nmbd
Apr 8 06:56:02 raspberrypi kernel: [425957.182436] [ 852] 0 852 1405 0 36864 102 0 login
Apr 8 06:56:02 raspberrypi kernel: [425957.182441] [ 904] 0 904 12091 509 118784 303 0 smbd
Apr 8 06:56:02 raspberrypi kernel: [425957.182447] [ 930] 0 930 535 19 28672 13 0 hciattach
Apr 8 06:56:02 raspberrypi kernel: [425957.182453] [ 935] 0 935 11357 244 110592 330 0 smbd-notifyd
Apr 8 06:56:02 raspberrypi kernel: [425957.182458] [ 936] 0 936 11358 259 110592 327 0 cleanupd
Apr 8 06:56:02 raspberrypi kernel: [425957.182463] [ 937] 0 937 2452 204 36864 51 0 bluetoothd
Apr 8 06:56:02 raspberrypi kernel: [425957.182468] [ 938] 0 938 12088 253 110592 331 0 lpqd
Apr 8 06:56:02 raspberrypi kernel: [425957.182473] [ 940] 0 940 6677 0 57344 101 0 bluealsa
Apr 8 06:56:02 raspberrypi kernel: [425957.182479] [ 1472] 1000 1472 2123 29 45056 214 0 bash
Apr 8 06:56:02 raspberrypi kernel: [425957.182484] [ 1597] 0 1597 485 12 32768 7 0 hassio-supervis
Apr 8 06:56:02 raspberrypi kernel: [425957.182490] [ 1624] 0 1624 236379 2319 212992 3253 0 docker
Apr 8 06:56:02 raspberrypi kernel: [425957.182496] [ 1665] 0 1665 199794 315 40960 15 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182501] [ 1692] 0 1692 49 0 24576 1 0 s6-svscan
Apr 8 06:56:02 raspberrypi kernel: [425957.182506] [ 1840] 0 1840 50 0 20480 3 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182512] [ 1987] 0 1987 493 143 32768 25 -1000 udevd
Apr 8 06:56:02 raspberrypi kernel: [425957.182517] [ 2075] 0 2075 50 1 20480 0 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182523] [ 2077] 0 2077 37928 9150 290816 808 0 python3
Apr 8 06:56:02 raspberrypi kernel: [425957.182528] [ 2196] 0 2196 1821 4 36864 72 0 socat
Apr 8 06:56:02 raspberrypi kernel: [425957.182534] [ 2223] 0 2223 199970 410 40960 0 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182539] [ 2242] 0 2242 199794 302 40960 44 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182544] [ 2280] 0 2280 199794 313 36864 49 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182550] [ 2302] 0 2302 49 0 20480 4 0 s6-svscan
Apr 8 06:56:02 raspberrypi kernel: [425957.182555] [ 2317] 0 2317 49 0 24576 5 0 s6-svscan
Apr 8 06:56:02 raspberrypi kernel: [425957.182561] [ 2337] 0 2337 49 1 24576 0 0 s6-svscan
Apr 8 06:56:02 raspberrypi kernel: [425957.182566] [ 2526] 0 2526 50 1 24576 0 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182571] [ 2850] 0 2850 45 0 16384 3 0 foreground
Apr 8 06:56:02 raspberrypi kernel: [425957.182577] [ 2851] 0 2851 45 2 16384 0 0 foreground
Apr 8 06:56:02 raspberrypi kernel: [425957.182582] [ 2855] 0 2855 50 0 20480 3 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182588] [ 2856] 0 2856 50 1 20480 0 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182594] [ 2904] 0 2904 44 1 16384 0 0 foreground
Apr 8 06:56:02 raspberrypi kernel: [425957.182600] [ 2908] 0 2908 44 1 16384 0 0 foreground
Apr 8 06:56:02 raspberrypi kernel: [425957.182606] [ 3192] 0 3192 324 1 20480 0 0 sleep
Apr 8 06:56:02 raspberrypi kernel: [425957.182612] [ 3227] 0 3227 207525 1448 122880 172 0 coredns
Apr 8 06:56:02 raspberrypi kernel: [425957.182617] [ 3260] 0 3260 1489 95 32768 106 -1000 udevd
Apr 8 06:56:02 raspberrypi kernel: [425957.182623] [ 3283] 0 3283 50 0 20480 3 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182628] [ 3286] 0 3286 20032 162 53248 328 0 pulseaudio
Apr 8 06:56:02 raspberrypi kernel: [425957.182634] [ 3342] 0 3342 199970 304 45056 60 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182640] [ 3383] 0 3383 215523 0 90112 303 -500 docker-proxy
Apr 8 06:56:02 raspberrypi kernel: [425957.182645] [ 3393] 0 3393 49 0 24576 4 0 s6-svscan
Apr 8 06:56:02 raspberrypi kernel: [425957.182651] [ 3404] 0 3404 215523 33 86016 303 -500 docker-proxy
Apr 8 06:56:02 raspberrypi kernel: [425957.182656] [ 3423] 0 3423 215523 21 98304 292 -500 docker-proxy
Apr 8 06:56:02 raspberrypi kernel: [425957.182662] [ 3439] 0 3439 213282 0 86016 273 -500 docker-proxy
Apr 8 06:56:02 raspberrypi kernel: [425957.182667] [ 3453] 0 3453 199794 372 36864 57 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182673] [ 3471] 0 3471 179 10 24576 3 0 docker-init
Apr 8 06:56:02 raspberrypi kernel: [425957.182679] [ 3605] 0 3605 50 0 20480 2 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182684] [ 3756] 0 3756 50 0 24576 2 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182820] [ 3759] 0 3759 1685 102 36864 186 0 bash
Apr 8 06:56:02 raspberrypi kernel: [425957.182826] [ 3801] 0 3801 1438 313 32768 21 0 mysqld_safe
Apr 8 06:56:02 raspberrypi kernel: [425957.182831] [ 3864] 0 3864 679 13 24576 271 0 bash
Apr 8 06:56:02 raspberrypi kernel: [425957.182837] [ 4076] 0 4076 823 12 28672 44 0 socat
Apr 8 06:56:02 raspberrypi kernel: [425957.182842] [ 4077] 0 4077 4216 1063 61440 2401 0 mosquitto
Apr 8 06:56:02 raspberrypi kernel: [425957.182848] [ 4739] 0 4739 199794 327 36864 62 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182854] [ 4757] 0 4757 199794 361 40960 47 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182859] [ 4772] 0 4772 179 9 24576 4 0 docker-init
Apr 8 06:56:02 raspberrypi kernel: [425957.182865] [ 4798] 0 4798 179 13 24576 0 0 docker-init
Apr 8 06:56:02 raspberrypi kernel: [425957.182871] [ 4824] 0 4824 49 0 24576 10 0 s6-svscan
Apr 8 06:56:02 raspberrypi kernel: [425957.182877] [ 4876] 0 4876 50 0 24576 3 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182883] [ 5229] 0 5229 4336 993 61440 1448 0 hass-configurat
Apr 8 06:56:02 raspberrypi kernel: [425957.182889] [ 5338] 0 5338 50 0 24576 3 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182894] [ 5339] 0 5339 50 0 20480 3 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182900] [ 5343] 0 5343 13406 2336 81920 1775 0 esphome
Apr 8 06:56:02 raspberrypi kernel: [425957.182905] [ 5345] 0 5345 1464 23 36864 99 0 nginx
Apr 8 06:56:02 raspberrypi kernel: [425957.182911] [ 5399] 0 5399 1511 80 32768 83 0 nginx
Apr 8 06:56:02 raspberrypi kernel: [425957.182917] [ 5997] 0 5997 199794 343 45056 20 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182922] [ 6014] 0 6014 49 0 24576 8 0 s6-svscan
Apr 8 06:56:02 raspberrypi kernel: [425957.182928] [ 6052] 0 6052 50 0 24576 2 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182934] [ 6199] 0 6199 2483 45 32768 67 -1000 udevd
Apr 8 06:56:02 raspberrypi kernel: [425957.182940] [ 6384] 0 6384 50 0 24576 2 0 s6-supervise
Apr 8 06:56:02 raspberrypi kernel: [425957.182946] [ 6385] 0 6385 42635 17025 360448 534 0 python3
Apr 8 06:56:02 raspberrypi kernel: [425957.182952] [ 10648] 1000 10648 6499 117 45056 95 0 dconf-service
Apr 8 06:56:02 raspberrypi kernel: [425957.182957] [ 10717] 1000 10717 36974 2611 192512 245 0 mousepad
Apr 8 06:56:02 raspberrypi kernel: [425957.182963] [ 12944] 1000 12944 16128 367 94208 12 0 gvfsd-network
Apr 8 06:56:02 raspberrypi kernel: [425957.182968] [ 12971] 1000 12971 15900 449 98304 25 0 gvfsd-dnssd
Apr 8 06:56:02 raspberrypi kernel: [425957.182976] [ 13588] 0 13588 208608 276 65536 0 -500 docker-proxy
Apr 8 06:56:02 raspberrypi kernel: [425957.182984] [ 13604] 0 13604 199794 359 40960 10 -999 containerd-shim
Apr 8 06:56:02 raspberrypi kernel: [425957.182991] [ 13621] 0 13621 203301 1762 86016 21 0 portainer
Apr 8 06:56:02 raspberrypi kernel: [425957.182997] [ 26003] 0 26003 1866 108 32768 0 0 git
Apr 8 06:56:02 raspberrypi kernel: [425957.183008] [ 11166] 0 11166 485 89 28672 0 0 apt.systemd.dai
Apr 8 06:56:02 raspberrypi kernel: [425957.183014] [ 11170] 0 11170 485 276 28672 0 0 apt.systemd.dai
Apr 8 06:56:02 raspberrypi kernel: [425957.183021] [ 11195] 0 11195 80294 11520 270336 0 0 mysqld
Apr 8 06:56:02 raspberrypi kernel: [425957.183027] [ 11246] 0 11246 10768 7888 114688 0 0 apt-get
Apr 8 06:56:02 raspberrypi kernel: [425957.183034] [ 11408] 0 11408 21135 2955 102400 0 0 packagekitd
Apr 8 06:56:02 raspberrypi kernel: [425957.183039] Out of memory: Kill process 6385 (python3) score 67 or sacrifice child
Apr 8 06:56:02 raspberrypi kernel: [425957.183130] Killed process 6385 (python3) total-vm:170540kB, anon-rss:66028kB, file-rss:2072kB, shmem-rss:0kB
Apr 8 06:56:02 raspberrypi kernel: [425957.197086] oom_reaper: reaped process 6385 (python3), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.6525] policy: auto-activating connection 'Wired connection 4' (0eddea39-9be3-3833-a05a-6a1ff074acc8)
Apr 8 06:56:02 raspberrypi dhcpcd[374]: vethe6fe7a5: adding route to 169.254.0.0/16
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.6560] device (vethe6fe7a5): Activation: starting connection 'Wired connection 4' (0eddea39-9be3-3833-a05a-6a1ff074acc8)
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Withdrawing address record for 169.254.44.232 on vethe6fe7a5.
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.6565] device (vethe6fe7a5): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Leaving mDNS multicast group on interface vethe6fe7a5.IPv4 with address 169.254.44.232.
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.6582] device (vethe6fe7a5): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Interface vethe6fe7a5.IPv4 no longer relevant for mDNS.
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.6605] device (vethe6fe7a5): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 8 06:56:02 raspberrypi dhcpcd[374]: vethe6fe7a5: pid 351 deleted IP address 169.254.44.232/16
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.6970] dhcp4 (vethe6fe7a5): activation: beginning transaction (timeout in 45 seconds)
Apr 8 06:56:02 raspberrypi dhcpcd[374]: vethe6fe7a5: deleting route to 169.254.0.0/16
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.7248] dhcp4 (vethe6fe7a5): dhclient started with pid 11420
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Joining mDNS multicast group on interface vethe6fe7a5.IPv6 with address fe80::99b6:81a0:8cc2:d1bc.
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.7404] device (vethe6fe7a5): ipv6: duplicate address check failed for the fe80::99b6:81a0:8cc2:d1bc/64 lft forever pref forever lifetime 425944-0[4294967295,4294967295] dev 23 flags permanent,noprefixroute,tentative src kernel address
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: New relevant interface vethe6fe7a5.IPv6 for mDNS.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Registering new address record for fe80::99b6:81a0:8cc2:d1bc on vethe6fe7a5.*.
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <info> [1586321762.7508] device (vethe6fe7a5): ipv6: duplicate address check failed for the fe80::5d0d:cce6:d8fb:26ef/64 lft forever pref forever lifetime 425944-0[4294967295,4294967295] dev 23 flags permanent,noprefixroute,tentative src kernel address
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Withdrawing address record for fe80::99b6:81a0:8cc2:d1bc on vethe6fe7a5.
Apr 8 06:56:02 raspberrypi NetworkManager[351]: <warn> [1586321762.7509] device (vethe6fe7a5): linklocal6: failed to generate an address: Too many DAD collisions
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Leaving mDNS multicast group on interface vethe6fe7a5.IPv6 with address fe80::99b6:81a0:8cc2:d1bc.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Joining mDNS multicast group on interface vethe6fe7a5.IPv6 with address fe80::5d0d:cce6:d8fb:26ef.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Registering new address record for fe80::5d0d:cce6:d8fb:26ef on vethe6fe7a5.*.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Withdrawing address record for fe80::5d0d:cce6:d8fb:26ef on vethe6fe7a5.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Leaving mDNS multicast group on interface vethe6fe7a5.IPv6 with address fe80::5d0d:cce6:d8fb:26ef.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Joining mDNS multicast group on interface vethe6fe7a5.IPv6 with address fe80::b13:840f:6a5c:84d0.
Apr 8 06:56:02 raspberrypi avahi-daemon[319]: Registering new address record for fe80::b13:840f:6a5c:84d0 on vethe6fe7a5.*.
Apr 8 06:56:02 raspberrypi dhcpcd[374]: vethe6fe7a5: probing for an IPv4LL address
Apr 8 06:56:02 raspberrypi dhclient[11420]: DHCPDISCOVER on vethe6fe7a5 to 255.255.255.255 port 67 interval 4
Apr 8 06:56:03 raspberrypi NetworkManager[351]: <warn> [1586321763.8464] device (vethe6fe7a5): linklocal6: failed to generate an address: Too many DAD collisions
Apr 8 06:56:06 raspberrypi dhclient[11420]: DHCPDISCOVER on vethe6fe7a5 to 255.255.255.255 port 67 interval 4
Apr 8 06:56:06 raspberrypi containerd[473]: time="2020-04-08T06:56:06.752596799+02:00" level=info msg="shim reaped" id=b7660dfa813c1dab26610eac4dca19b82c1edd9459a46568e2a7aecf73e85603
Apr 8 06:56:06 raspberrypi dockerd[842]: time="2020-04-08T06:56:06.764919658+02:00" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 8 06:56:06 raspberrypi systemd[563]: var-lib-docker-overlay2-ee4bf2b01fb00c073521194d80d930360644baf2a070176e8eecf2f3eeb8d743-merged.mount: Succeeded.
Apr 8 06:56:06 raspberrypi systemd[1]: var-lib-docker-overlay2-ee4bf2b01fb00c073521194d80d930360644baf2a070176e8eecf2f3eeb8d743-merged.mount: Succeeded.
Apr 8 06:56:07 raspberrypi dhcpcd[374]: vethe6fe7a5: using IPv4LL address 169.254.134.10
Apr 8 06:56:07 raspberrypi avahi-daemon[319]: Joining mDNS multicast group on interface vethe6fe7a5.IPv4 with address 169.254.134.10.
cmoers
(Cedric Moers)
April 8, 2020, 8:06am
4
Crash of April 3
Apr 3 00:58:31 raspberrypi hassio-supervisor[1419]: #033[32m20-04-02 22:58:31 INFO (MainThread) [supervisor.tasks] Found new PulseAudio plugin version#033[0m
Apr 3 00:58:31 raspberrypi hassio-supervisor[1419]: #033[32m20-04-02 22:58:31 INFO (SyncWorker_8) [supervisor.docker.interface] Update image homeassistant/armv7-hassio-audio:9 to homeassistant/armv7-hassio-audio:14#033[0m
Apr 3 00:58:31 raspberrypi hassio-supervisor[1419]: #033[32m20-04-02 22:58:31 INFO (SyncWorker_8) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-audio tag 14.#033[0m
Apr 3 00:58:39 raspberrypi dhcpcd[376]: eth0: Router Advertisement from fe80::362c:c4ff:fe87:67bc
Apr 3 00:58:42 raspberrypi hassio-supervisor[1419]: #033[32m20-04-02 22:58:42 INFO (SyncWorker_8) [supervisor.docker.interface] Stop hassio_audio application#033[0m
Apr 3 00:58:46 raspberrypi containerd[468]: time="2020-04-03T00:58:46.564598660+02:00" level=info msg="shim reaped" id=fdadc2dee7015f8be00f97ac9367a63062ad44267868b939a831588cb2124600
Apr 3 00:58:46 raspberrypi dockerd[843]: time="2020-04-03T00:58:46.578394459+02:00" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 3 00:58:46 raspberrypi dhcpcd[376]: veth9a9d7e0: carrier lost
Apr 3 00:58:46 raspberrypi kernel: [120880.840097] hassio: port 3(veth9a9d7e0) entered disabled state
Apr 3 00:58:46 raspberrypi kernel: [120880.840309] veth67d5395: renamed from eth0
Apr 3 00:58:46 raspberrypi dhcpcd[376]: veth9a9d7e0: deleting address fe80::9d65:d9c1:8e54:8ad9
Apr 3 00:58:46 raspberrypi avahi-daemon[321]: Withdrawing address record for fe80::9d65:d9c1:8e54:8ad9 on veth9a9d7e0.
Apr 3 00:58:46 raspberrypi avahi-daemon[321]: Leaving mDNS multicast group on interface veth9a9d7e0.IPv6 with address fe80::9d65:d9c1:8e54:8ad9.
Apr 3 00:58:46 raspberrypi avahi-daemon[321]: Interface veth9a9d7e0.IPv6 no longer relevant for mDNS.
Apr 3 00:58:46 raspberrypi systemd-udevd[17518]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Apr 3 00:58:46 raspberrypi systemd-udevd[17518]: Using default interface naming scheme 'v240'.
Apr 3 00:58:46 raspberrypi avahi-daemon[321]: Interface veth9a9d7e0.IPv4 no longer relevant for mDNS.
Apr 3 00:58:46 raspberrypi avahi-daemon[321]: Leaving mDNS multicast group on interface veth9a9d7e0.IPv4 with address 169.254.72.203.
Apr 3 00:58:46 raspberrypi kernel: [120880.974146] hassio: port 3(veth9a9d7e0) entered disabled state
Apr 3 00:58:46 raspberrypi avahi-daemon[321]: Withdrawing address record for 169.254.72.203 on veth9a9d7e0.
Apr 3 00:58:46 raspberrypi kernel: [120880.983985] device veth9a9d7e0 left promiscuous mode
Apr 3 00:58:46 raspberrypi kernel: [120880.983996] hassio: port 3(veth9a9d7e0) entered disabled state
Apr 3 00:58:46 raspberrypi dhcpcd[376]: veth9a9d7e0: deleting route to 169.254.0.0/16
Apr 3 00:58:46 raspberrypi systemd[1]: run-docker-netns-d118e4e56518.mount: Succeeded.
Apr 3 00:58:46 raspberrypi systemd[566]: run-docker-netns-d118e4e56518.mount: Succeeded.
Apr 3 00:58:46 raspberrypi dhcpcd[376]: veth9a9d7e0: removing interface
Apr 3 00:58:46 raspberrypi systemd[1]: var-lib-docker-overlay2-f024232b2386152f8c4177084ad83d9baac4f3cf2e3de4a57cd214801cf1b40b-merged.mount: Succeeded.
Apr 3 00:58:46 raspberrypi systemd[566]: var-lib-docker-overlay2-f024232b2386152f8c4177084ad83d9baac4f3cf2e3de4a57cd214801cf1b40b-merged.mount: Succeeded.
Apr 3 00:58:46 raspberrypi hassio-supervisor[1419]: #033[32m20-04-02 22:58:46 INFO (SyncWorker_8) [supervisor.docker.interface] Clean hassio_audio application#033[0m
Apr 3 00:58:47 raspberrypi hassio-supervisor[1419]: #033[32m20-04-02 22:58:47 INFO (SyncWorker_7) [supervisor.docker.interface] Cleanup images: ['homeassistant/armv7-hassio-audio:9']#033[0m
Apr 3 00:58:47 raspberrypi hassio-supervisor[1419]: #033[32m20-04-02 22:58:47 INFO (MainThread) [supervisor.audio] Start Audio plugin#033[0m
Apr 3 00:58:47 raspberrypi systemd[1]: var-lib-docker-overlay2-c0622e595fe87644f640ac4782f273040fd8f69a79e654a56faa22ca5c8559e5\x2dinit-merged.mount: Succeeded.
Apr 3 00:58:47 raspberrypi kernel: [120882.095062] hassio: port 3(vethcca6966) entered blocking state
Apr 3 00:58:47 raspberrypi kernel: [120882.095069] hassio: port 3(vethcca6966) entered disabled state
Apr 3 00:58:47 raspberrypi kernel: [120882.095477] device vethcca6966 entered promiscuous mode
Apr 3 00:58:47 raspberrypi kernel: [120882.096865] IPv6: ADDRCONF(NETDEV_UP): vethcca6966: link is not ready
Apr 3 00:58:47 raspberrypi systemd-udevd[17524]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Apr 3 00:58:47 raspberrypi systemd-udevd[17523]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Apr 3 00:58:47 raspberrypi systemd-udevd[17524]: Using default interface naming scheme 'v240'.
Apr 3 00:58:47 raspberrypi systemd-udevd[17524]: Could not generate persistent MAC address for vethcca6966: No such file or directory
Apr 3 00:58:47 raspberrypi systemd-udevd[17523]: Using default interface naming scheme 'v240'.
Apr 3 00:58:47 raspberrypi systemd-udevd[17523]: Could not generate persistent MAC address for veth6160f4d: No such file or directory
Apr 3 00:58:47 raspberrypi kernel: [120882.144567] IPv6: ADDRCONF(NETDEV_UP): veth6160f4d: link is not ready
Apr 3 00:58:47 raspberrypi kernel: [120882.144965] IPv6: ADDRCONF(NETDEV_UP): veth6160f4d: link is not ready
Apr 3 00:58:47 raspberrypi kernel: [120882.144991] IPv6: ADDRCONF(NETDEV_CHANGE): veth6160f4d: link becomes ready
Apr 3 00:58:47 raspberrypi kernel: [120882.145189] IPv6: ADDRCONF(NETDEV_CHANGE): vethcca6966: link becomes ready
Apr 3 00:58:47 raspberrypi kernel: [120882.145303] hassio: port 3(vethcca6966) entered blocking state
Apr 3 00:58:47 raspberrypi kernel: [120882.145309] hassio: port 3(vethcca6966) entered forwarding state
Apr 3 00:58:48 raspberrypi dbus-daemon[331]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.8' (uid=0 pid=337 comm="/usr/sbin/NetworkManager --no-daemon ")
Apr 3 00:58:48 raspberrypi containerd[468]: time="2020-04-03T00:58:48.024024620+02:00" level=info msg="shim containerd-shim started" address="/containerd-shim/moby/947071cf1e3a5b30fa6db0862ce5d66fbce803588a8d6baefadd3b2f084f199a/shim.sock" debug=false pid=17566
Apr 3 00:58:48 raspberrypi systemd[1]: Starting Network Manager Script Dispatcher Service...
Apr 3 00:58:48 raspberrypi dbus-daemon[331]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Apr 3 00:58:48 raspberrypi systemd[1]: Started Network Manager Script Dispatcher Service.
Apr 3 00:58:48 raspberrypi nm-dispatcher: req:1 'up' [vethcca6966]: new request (1 scripts)
Apr 3 00:58:48 raspberrypi nm-dispatcher: req:1 'up' [vethcca6966]: start running ordered scripts...
Apr 3 00:58:49 raspberrypi kernel: [120883.361813] exe invoked oom-killer: gfp_mask=0x7080c0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), nodemask=(null), order=1, oom_score_adj=-500
Apr 3 00:58:49 raspberrypi kernel: [120883.361819] exe cpuset=/ mems_allowed=0
Apr 3 00:58:49 raspberrypi kernel: [120883.361831] CPU: 2 PID: 17640 Comm: exe Tainted: G C 4.19.97-v7l+ #1294
Apr 3 00:58:49 raspberrypi kernel: [120883.361834] Hardware name: BCM2835
Apr 3 00:58:49 raspberrypi kernel: [120883.361854] [<c0212e04>] (unwind_backtrace) from [<c020d5e0>] (show_stack+0x20/0x24)
Apr 3 00:58:49 raspberrypi kernel: [120883.361864] [<c020d5e0>] (show_stack) from [<c09b15c8>] (dump_stack+0xe0/0x124)
Apr 3 00:58:49 raspberrypi kernel: [120883.361875] [<c09b15c8>] (dump_stack) from [<c0363e28>] (dump_header+0x80/0x250)
Apr 3 00:58:49 raspberrypi kernel: [120883.361885] [<c0363e28>] (dump_header) from [<c0363190>] (oom_kill_process+0x358/0x3a8)
Apr 3 00:58:49 raspberrypi kernel: [120883.361891] [<c0363190>] (oom_kill_process) from [<c0363ac0>] (out_of_memory+0x134/0x37c)
Apr 3 00:58:49 raspberrypi kernel: [120883.361898] [<c0363ac0>] (out_of_memory) from [<c0369ea4>] (__alloc_pages_nodemask+0xfc0/0x1180)
Apr 3 00:58:49 raspberrypi kernel: [120883.361907] [<c0369ea4>] (__alloc_pages_nodemask) from [<c021f8c0>] (copy_process.part.5+0x1f4/0x1ad4)
Apr 3 00:58:49 raspberrypi kernel: [120883.361914] [<c021f8c0>] (copy_process.part.5) from [<c0221368>] (_do_fork+0xd8/0x438)
Apr 3 00:58:49 raspberrypi kernel: [120883.361921] [<c0221368>] (_do_fork) from [<c02217ec>] (sys_clone+0x34/0x3c)
Apr 3 00:58:49 raspberrypi kernel: [120883.361928] [<c02217ec>] (sys_clone) from [<c0201000>] (ret_fast_syscall+0x0/0x28)
Apr 3 00:58:49 raspberrypi kernel: [120883.361932] Exception stack(0xef4dbfa8 to 0xef4dbff0)
Apr 3 00:58:49 raspberrypi kernel: [120883.361937] bfa0: a6650398 beab8aac 003d0f00 a664fe68 a6650398 a66507f0
Apr 3 00:58:49 raspberrypi kernel: [120883.361942] bfc0: a6650398 beab8aac b6f330a0 00000078 beab8a22 a6650330 00000000 beab8a6c
Apr 3 00:58:49 raspberrypi kernel: [120883.361946] bfe0: 003d0f00 beab89b0 b6e1a180 b6ced558
Apr 3 00:58:49 raspberrypi kernel: [120883.361951] Mem-Info:
Apr 3 00:58:49 raspberrypi kernel: [120883.361960] active_anon:53594 inactive_anon:63130 isolated_anon:0
Apr 3 00:58:49 raspberrypi kernel: [120883.361960] active_file:8906 inactive_file:7491 isolated_file:0
Apr 3 00:58:49 raspberrypi kernel: [120883.361960] unevictable:4 dirty:2 writeback:0 unstable:0
Apr 3 00:58:49 raspberrypi kernel: [120883.361960] slab_reclaimable:9964 slab_unreclaimable:17782
Apr 3 00:58:49 raspberrypi kernel: [120883.361960] mapped:14737 shmem:8707 pagetables:2057 bounce:0
Apr 3 00:58:49 raspberrypi kernel: [120883.361960] free:65299 free_pcp:12 free_cma:60616
Apr 3 00:58:49 raspberrypi kernel: [120883.361968] Node 0 active_anon:214376kB inactive_anon:252520kB active_file:35624kB inactive_file:29964kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:58948kB dirty:8kB writeback:0kB shmem:34828kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
Apr 3 00:58:49 raspberrypi kernel: [120883.361977] DMA free:260268kB min:16384kB low:20480kB high:24576kB active_anon:160648kB inactive_anon:195284kB active_file:276kB inactive_file:600kB unevictable:0kB writepending:12kB present:786432kB managed:762316kB mlocked:0kB kernel_stack:4616kB pagetables:5356kB bounce:0kB free_pcp:48kB local_pcp:0kB free_cma:242464kB
Apr 3 00:58:49 raspberrypi kernel: [120883.361980] lowmem_reserve[]: 0 0 180 180
Apr 3 00:58:49 raspberrypi kernel: [120883.361994] HighMem free:928kB min:180kB low:1168kB high:2156kB active_anon:53748kB inactive_anon:57236kB active_file:35420kB inactive_file:29456kB unevictable:16kB writepending:0kB present:184320kB managed:184320kB mlocked:16kB kernel_stack:0kB pagetables:2872kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Apr 3 00:58:49 raspberrypi kernel: [120883.361998] lowmem_reserve[]: 0 0 0 0
Apr 3 00:58:49 raspberrypi kernel: [120883.362006] DMA: 1827*4kB (UMEHC) 866*8kB (UMEHC) 167*16kB (UMEHC) 63*32kB (UMEHC) 33*64kB (UHC) 4*128kB (HC) 1*256kB (C) 0*512kB 1*1024kB (C) 0*2048kB 58*4096kB (C) = 260396kB
Apr 3 00:58:49 raspberrypi kernel: [120883.362128] HighMem: 59*4kB (U) 21*8kB (UM) 13*16kB (UM) 8*32kB (UM) 1*64kB (U) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 932kB
Apr 3 00:58:49 raspberrypi kernel: [120883.362153] 26181 total pagecache pages
Apr 3 00:58:49 raspberrypi kernel: [120883.362158] 1029 pages in swap cache
Apr 3 00:58:49 raspberrypi kernel: [120883.362162] Swap cache stats: add 39478, delete 38449, find 76261/80201
Apr 3 00:58:49 raspberrypi kernel: [120883.362167] Free swap = 0kB
Apr 3 00:58:49 raspberrypi kernel: [120883.362171] Total swap = 102396kB
Apr 3 00:58:49 raspberrypi kernel: [120883.362176] 242688 pages RAM
Apr 3 00:58:49 raspberrypi kernel: [120883.362180] 46080 pages HighMem/MovableOnly
Apr 3 00:58:49 raspberrypi kernel: [120883.362185] 6029 pages reserved
Apr 3 00:58:49 raspberrypi kernel: [120883.362188] 65536 pages cma reserved
Apr 3 00:58:49 raspberrypi kernel: [120883.362192] Tasks state (memory values in pages):
Apr 3 00:58:49 raspberrypi kernel: [120883.362196] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
Apr 3 00:58:49 raspberrypi kernel: [120883.362211] [ 115] 0 115 8320 2061 217088 48 0 systemd-journal
Apr 3 00:58:49 raspberrypi kernel: [120883.362218] [ 141] 0 141 4621 591 49152 61 -1000 systemd-udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.362227] [ 281] 100 281 5603 657 57344 21 0 systemd-timesyn
Apr 3 00:58:49 raspberrypi kernel: [120883.362233] [ 320] 0 320 16695 1328 90112 291 0 udisksd
Apr 3 00:58:49 raspberrypi kernel: [120883.362239] [ 321] 108 321 1507 595 32768 28 0 avahi-daemon
Apr 3 00:58:49 raspberrypi kernel: [120883.362245] [ 323] 0 323 923 340 32768 19 0 alsactl
Apr 3 00:58:49 raspberrypi kernel: [120883.362251] [ 326] 0 326 13664 826 86016 16 0 ModemManager
Apr 3 00:58:49 raspberrypi kernel: [120883.362257] [ 328] 0 328 3287 821 53248 31 0 systemd-logind
Apr 3 00:58:49 raspberrypi kernel: [120883.362263] [ 329] 0 329 6378 625 53248 20 0 rsyslogd
Apr 3 00:58:49 raspberrypi kernel: [120883.362271] [ 331] 104 331 1749 697 36864 43 -900 dbus-daemon
Apr 3 00:58:49 raspberrypi kernel: [120883.362280] [ 334] 108 334 1443 21 32768 42 0 avahi-daemon
Apr 3 00:58:49 raspberrypi kernel: [120883.362287] [ 336] 0 336 6914 319 40960 6 0 rngd
Apr 3 00:58:49 raspberrypi kernel: [120883.362293] [ 337] 0 337 17147 1470 110592 59 0 NetworkManager
Apr 3 00:58:49 raspberrypi kernel: [120883.362298] [ 341] 0 341 1987 391 40960 14 0 cron
Apr 3 00:58:49 raspberrypi kernel: [120883.362304] [ 342] 65534 342 1080 381 32768 17 0 thd
Apr 3 00:58:49 raspberrypi kernel: [120883.362309] [ 349] 0 349 2716 642 49152 36 0 wpa_supplicant
Apr 3 00:58:49 raspberrypi kernel: [120883.362314] [ 376] 0 376 907 539 32768 93 0 dhcpcd
Apr 3 00:58:49 raspberrypi kernel: [120883.362320] [ 414] 0 414 10478 913 69632 279 0 polkitd
Apr 3 00:58:49 raspberrypi kernel: [120883.362326] [ 460] 0 460 11068 1791 94208 78 0 unattended-upgr
Apr 3 00:58:49 raspberrypi kernel: [120883.362331] [ 464] 0 464 2157 216 45056 20 0 vncserver-x11-s
Apr 3 00:58:49 raspberrypi kernel: [120883.362337] [ 468] 0 468 256423 5724 221184 107 0 containerd
Apr 3 00:58:49 raspberrypi kernel: [120883.362342] [ 469] 0 469 9580 857 90112 780 0 vncserver-x11-c
Apr 3 00:58:49 raspberrypi kernel: [120883.362348] [ 480] 0 480 10027 656 73728 0 0 lightdm
Apr 3 00:58:49 raspberrypi kernel: [120883.362353] [ 482] 0 482 2681 458 45056 74 -1000 sshd
Apr 3 00:58:49 raspberrypi kernel: [120883.362359] [ 498] 0 498 2776 471 49152 0 0 wpa_supplicant
Apr 3 00:58:49 raspberrypi kernel: [120883.362364] [ 522] 0 522 41291 4981 274432 0 0 Xorg
Apr 3 00:58:49 raspberrypi kernel: [120883.362370] [ 544] 0 544 2870 423 45056 41 0 vncagent
Apr 3 00:58:49 raspberrypi kernel: [120883.362375] [ 558] 0 558 8133 663 65536 8 0 lightdm
Apr 3 00:58:49 raspberrypi kernel: [120883.362380] [ 566] 1000 566 3706 992 53248 152 0 systemd
Apr 3 00:58:49 raspberrypi kernel: [120883.362386] [ 569] 1000 569 4217 334 61440 298 0 (sd-pam)
Apr 3 00:58:49 raspberrypi kernel: [120883.362391] [ 580] 1000 580 14085 368 102400 258 0 lxsession
Apr 3 00:58:49 raspberrypi kernel: [120883.362397] [ 589] 1000 589 1636 538 36864 65 0 dbus-daemon
Apr 3 00:58:49 raspberrypi kernel: [120883.362405] [ 615] 1000 615 1130 153 32768 62 0 ssh-agent
Apr 3 00:58:49 raspberrypi kernel: [120883.362412] [ 625] 1000 625 10853 502 69632 120 0 gvfsd
Apr 3 00:58:49 raspberrypi kernel: [120883.362417] [ 630] 1000 630 14193 376 77824 188 0 gvfsd-fuse
Apr 3 00:58:49 raspberrypi kernel: [120883.362424] [ 636] 1000 636 15819 596 102400 503 0 openbox
Apr 3 00:58:49 raspberrypi kernel: [120883.362431] [ 641] 1000 641 11783 510 98304 268 0 lxpolkit
Apr 3 00:58:49 raspberrypi kernel: [120883.362438] [ 644] 1000 644 39821 2105 196608 996 0 lxpanel
Apr 3 00:58:49 raspberrypi kernel: [120883.362444] [ 646] 1000 646 29029 990 147456 679 0 pcmanfm
Apr 3 00:58:49 raspberrypi kernel: [120883.362450] [ 656] 1000 656 485 46 28672 17 0 cmstart.sh
Apr 3 00:58:49 raspberrypi kernel: [120883.362456] [ 657] 1000 657 1130 0 32768 72 0 ssh-agent
Apr 3 00:58:49 raspberrypi kernel: [120883.362462] [ 661] 1000 661 485 36 28672 20 0 sh
Apr 3 00:58:49 raspberrypi kernel: [120883.362468] [ 666] 1000 666 1218 0 32768 68 0 xcompmgr
Apr 3 00:58:49 raspberrypi kernel: [120883.362474] [ 669] 1000 669 58488 1421 327680 2309 0 zenity
Apr 3 00:58:49 raspberrypi kernel: [120883.362479] [ 689] 1000 689 7176 395 53248 152 0 menu-cached
Apr 3 00:58:49 raspberrypi kernel: [120883.362485] [ 691] 1000 691 19895 1127 98304 127 0 gvfs-udisks2-vo
Apr 3 00:58:49 raspberrypi kernel: [120883.362490] [ 697] 1000 697 14007 497 94208 144 0 gvfs-afc-volume
Apr 3 00:58:49 raspberrypi kernel: [120883.362496] [ 702] 1000 702 10032 416 65536 128 0 gvfs-mtp-volume
Apr 3 00:58:49 raspberrypi kernel: [120883.362501] [ 706] 1000 706 10026 264 69632 124 0 gvfs-goa-volume
Apr 3 00:58:49 raspberrypi kernel: [120883.362507] [ 710] 1000 710 10424 479 65536 84 0 gvfs-gphoto2-vo
Apr 3 00:58:49 raspberrypi kernel: [120883.362512] [ 733] 1000 733 13811 899 90112 8 0 gvfsd-trash
Apr 3 00:58:49 raspberrypi kernel: [120883.362517] [ 756] 1000 756 8029 825 86016 185 0 vncserverui
Apr 3 00:58:49 raspberrypi kernel: [120883.362524] [ 765] 1000 765 7940 973 86016 16 0 vncserverui
Apr 3 00:58:49 raspberrypi kernel: [120883.362530] [ 768] 1000 768 7745 327 61440 26 0 gvfsd-metadata
Apr 3 00:58:49 raspberrypi kernel: [120883.362542] [ 782] 0 782 1978 401 36864 171 0 dhclient
Apr 3 00:58:49 raspberrypi kernel: [120883.362548] [ 841] 0 841 8024 628 86016 233 0 nmbd
Apr 3 00:58:49 raspberrypi kernel: [120883.362556] [ 843] 0 843 256070 9624 299008 4534 -500 dockerd
Apr 3 00:58:49 raspberrypi kernel: [120883.362562] [ 852] 0 852 1405 300 36864 84 0 login
Apr 3 00:58:49 raspberrypi kernel: [120883.362569] [ 901] 0 901 12091 755 118784 352 0 smbd
Apr 3 00:58:49 raspberrypi kernel: [120883.362576] [ 926] 0 926 535 26 24576 6 0 hciattach
Apr 3 00:58:49 raspberrypi kernel: [120883.362582] [ 931] 0 931 2452 446 45056 36 0 bluetoothd
Apr 3 00:58:49 raspberrypi kernel: [120883.362588] [ 935] 0 935 11357 384 110592 366 0 smbd-notifyd
Apr 3 00:58:49 raspberrypi kernel: [120883.362595] [ 936] 0 936 11358 359 110592 359 0 cleanupd
Apr 3 00:58:49 raspberrypi kernel: [120883.362601] [ 937] 0 937 12088 381 110592 362 0 lpqd
Apr 3 00:58:49 raspberrypi kernel: [120883.362606] [ 939] 0 939 6677 283 53248 85 0 bluealsa
Apr 3 00:58:49 raspberrypi kernel: [120883.362612] [ 1419] 0 1419 485 244 32768 7 0 hassio-supervis
Apr 3 00:58:49 raspberrypi kernel: [120883.362618] [ 1434] 1000 1434 2123 371 40960 147 0 bash
Apr 3 00:58:49 raspberrypi kernel: [120883.362625] [ 1467] 0 1467 234266 2458 212992 3218 0 docker
Apr 3 00:58:49 raspberrypi kernel: [120883.362631] [ 1505] 0 1505 199794 194 45056 21 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362638] [ 1537] 0 1537 49 1 24576 0 0 s6-svscan
Apr 3 00:58:49 raspberrypi kernel: [120883.362644] [ 1682] 0 1682 50 1 24576 0 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362649] [ 1829] 0 1829 525 215 28672 0 -1000 udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.362655] [ 1911] 0 1911 50 1 24576 0 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362660] [ 1912] 0 1912 35883 7519 270336 395 0 python3
Apr 3 00:58:49 raspberrypi kernel: [120883.362668] [ 1988] 0 1988 1821 76 32768 0 0 socat
Apr 3 00:58:49 raspberrypi kernel: [120883.362674] [ 2043] 0 2043 199794 125 40960 57 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362680] [ 2075] 0 2075 199794 185 40960 9 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362687] [ 2129] 0 2129 49 0 24576 4 0 s6-svscan
Apr 3 00:58:49 raspberrypi kernel: [120883.362693] [ 2145] 0 2145 49 1 20480 0 0 s6-svscan
Apr 3 00:58:49 raspberrypi kernel: [120883.362699] [ 2411] 0 2411 45 2 16384 0 0 foreground
Apr 3 00:58:49 raspberrypi kernel: [120883.362705] [ 2412] 0 2412 45 2 16384 0 0 foreground
Apr 3 00:58:49 raspberrypi kernel: [120883.362712] [ 2414] 0 2414 50 1 24576 0 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362718] [ 2416] 0 2416 50 1 20480 0 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362724] [ 2450] 0 2450 44 1 16384 0 0 foreground
Apr 3 00:58:49 raspberrypi kernel: [120883.362730] [ 2452] 0 2452 44 1 16384 0 0 foreground
Apr 3 00:58:49 raspberrypi kernel: [120883.362736] [ 2920] 0 2920 324 1 20480 0 0 sleep
Apr 3 00:58:49 raspberrypi kernel: [120883.362742] [ 2937] 0 2937 207525 1433 118784 26 0 coredns
Apr 3 00:58:49 raspberrypi kernel: [120883.362748] [ 3221] 0 3221 199794 152 45056 40 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362754] [ 3240] 0 3240 215523 87 77824 296 -500 docker-proxy
Apr 3 00:58:49 raspberrypi kernel: [120883.362760] [ 3250] 0 3250 49 0 20480 5 0 s6-svscan
Apr 3 00:58:49 raspberrypi kernel: [120883.362767] [ 3262] 0 3262 215523 102 86016 291 -500 docker-proxy
Apr 3 00:58:49 raspberrypi kernel: [120883.362775] [ 3281] 0 3281 215523 107 90112 289 -500 docker-proxy
Apr 3 00:58:49 raspberrypi kernel: [120883.362781] [ 3297] 0 3297 215587 106 90112 245 -500 docker-proxy
Apr 3 00:58:49 raspberrypi kernel: [120883.362787] [ 3311] 0 3311 199794 160 40960 43 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362795] [ 3332] 0 3332 179 4 24576 4 0 docker-init
Apr 3 00:58:49 raspberrypi kernel: [120883.362801] [ 3470] 0 3470 50 0 24576 3 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362808] [ 3618] 0 3618 50 0 24576 3 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362815] [ 3622] 0 3622 1688 304 36864 19 0 bash
Apr 3 00:58:49 raspberrypi kernel: [120883.362821] [ 3662] 0 3662 1430 48 28672 63 0 mysqld_safe
Apr 3 00:58:49 raspberrypi kernel: [120883.362828] [ 3710] 0 3710 679 1 36864 283 0 bash
Apr 3 00:58:49 raspberrypi kernel: [120883.362834] [ 3858] 0 3858 80726 17315 339968 1914 0 mysqld
Apr 3 00:58:49 raspberrypi kernel: [120883.362841] [ 3966] 0 3966 823 13 24576 44 0 socat
Apr 3 00:58:49 raspberrypi kernel: [120883.362848] [ 3967] 0 3967 4216 1957 61440 1480 0 mosquitto
Apr 3 00:58:49 raspberrypi kernel: [120883.362854] [ 4007] 0 4007 199794 303 40960 0 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362861] [ 4024] 0 4024 49 0 24576 4 0 s6-svscan
Apr 3 00:58:49 raspberrypi kernel: [120883.362867] [ 4066] 0 4066 50 1 24576 0 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362873] [ 4213] 0 4213 471 106 32768 73 -1000 udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.362880] [ 4376] 0 4376 50 0 24576 1 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362886] [ 4378] 0 4378 51355 25717 454656 642 0 python3
Apr 3 00:58:49 raspberrypi kernel: [120883.362893] [ 4602] 0 4602 199970 192 45056 5 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362899] [ 4603] 0 4603 199794 160 40960 37 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.362906] [ 4650] 0 4650 179 8 24576 0 0 docker-init
Apr 3 00:58:49 raspberrypi kernel: [120883.362912] [ 4665] 0 4665 179 8 20480 0 0 docker-init
Apr 3 00:58:49 raspberrypi kernel: [120883.362919] [ 4706] 0 4706 49 0 24576 10 0 s6-svscan
Apr 3 00:58:49 raspberrypi kernel: [120883.362925] [ 4732] 0 4732 50 0 24576 3 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362931] [ 5068] 0 5068 3867 1970 57344 251 0 hass-configurat
Apr 3 00:58:49 raspberrypi kernel: [120883.362937] [ 5198] 0 5198 50 0 24576 3 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362942] [ 5199] 0 5199 50 0 16384 3 0 s6-supervise
Apr 3 00:58:49 raspberrypi kernel: [120883.362948] [ 5202] 0 5202 1464 53 32768 69 0 nginx
Apr 3 00:58:49 raspberrypi kernel: [120883.362953] [ 5204] 0 5204 13406 3723 86016 128 0 esphome
Apr 3 00:58:49 raspberrypi kernel: [120883.362958] [ 5259] 0 5259 1511 33 28672 130 0 nginx
Apr 3 00:58:49 raspberrypi kernel: [120883.362965] [ 21620] 0 21620 1866 125 40960 0 0 git
Apr 3 00:58:49 raspberrypi kernel: [120883.362971] [ 1047] 0 1047 1866 123 36864 0 0 git
Apr 3 00:58:49 raspberrypi kernel: [120883.362981] [ 17518] 0 17518 4621 518 45056 60 0 systemd-udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.362991] [ 17520] 0 17520 471 42 28672 75 0 udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.362999] [ 17521] 0 17521 471 44 28672 73 0 udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.363005] [ 17522] 0 17522 471 44 28672 73 0 udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.363012] [ 17523] 0 17523 4621 520 45056 58 0 systemd-udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.363019] [ 17524] 0 17524 4621 520 45056 58 0 systemd-udevd
Apr 3 00:58:49 raspberrypi kernel: [120883.363024] [ 17563] 0 17563 1978 646 36864 0 0 dhclient
Apr 3 00:58:49 raspberrypi kernel: [120883.363030] [ 17566] 0 17566 199762 778 36864 0 -999 containerd-shim
Apr 3 00:58:49 raspberrypi kernel: [120883.363037] [ 17567] 0 17567 8181 972 61440 0 0 nm-dispatcher
Apr 3 00:58:49 raspberrypi kernel: [120883.363043] [ 17575] 0 17575 214916 1597 90112 0 -999 runc
Apr 3 00:58:49 raspberrypi kernel: [120883.363049] [ 17597] 0 17597 210130 1462 77824 0 0 runc:[2:INIT]
Apr 3 00:58:49 raspberrypi kernel: [120883.363055] [ 17611] 0 17611 231298 10989 208896 0 -999 exe
Apr 3 00:58:49 raspberrypi kernel: [120883.363060] [ 17640] 0 17640 216843 6978 118784 0 -500 exe
Apr 3 00:58:49 raspberrypi kernel: [120883.363065] Out of memory: Kill process 4378 (python3) score 100 or sacrifice child
Apr 3 00:58:49 raspberrypi kernel: [120883.363156] Killed process 4378 (python3) total-vm:205420kB, anon-rss:102040kB, file-rss:828kB, shmem-rss:0kB
Apr 3 00:58:49 raspberrypi kernel: [120883.381523] oom_reaper: reaped process 4378 (python3), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
cmoers
(Cedric Moers)
April 8, 2020, 8:25am
5
For the record, I just tried to increase my swap memory size from 100MB to 2GB, I do not know if this will solve the issue, but it’s worth a try.
Lipown
(Lipown)
September 6, 2020, 1:33pm
6
Sorted or not? I am having those issues also.
cmoers
(Cedric Moers)
September 7, 2020, 7:32am
7
Yes, the problem was solved by increasing swap mem. Since the change, it has been running for months without a problem.
Lipown
(Lipown)
September 7, 2020, 11:30am
8
I made a huge swap but the issue is persistent unfortunatelly.
cmoers
(Cedric Moers)
September 7, 2020, 12:08pm
9
It might help if you add these sensors to your configuration:
This way they are also logged into the history and the values can be viewed in a graph for a few minutes before your crash.
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /
- type: disk_use
arg: /
- type: disk_free
arg: /
- type: memory_use_percent
- type: memory_use
- type: memory_free
- type: swap_use_percent
- type: swap_use
- type: swap_free
- type: processor_use
jacoscar
(Jacopo)
May 29, 2021, 10:32am
10
How much memory do I need to run on a VM machine? I’ve currently allocated 6GB, do I need 16GB, 32GB or more?
