Anyone else seeing this? I think the timestamp is seconds since start so about every 2 hours it is remounting everything twice.
Is it a bug?
[228182.784105] audit: type=1334 audit(1643003697.007:487): prog-id=135 op=LOAD
[228182.784269] audit: type=1334 audit(1643003697.007:488): prog-id=136 op=LOAD
[228183.121118] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[228183.121141] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[228183.121338] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[228183.121381] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[228183.121407] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[228183.121844] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[228183.122149] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[228183.122431] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[228183.122597] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[228183.139246] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[228183.139284] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[228183.139300] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[228183.139331] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[228183.139347] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[228183.139361] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[228183.139376] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[228183.139391] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[228183.139405] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[228183.374118] audit: type=1334 audit(1643003697.595:489): prog-id=137 op=LOAD
[228183.374163] audit: type=1334 audit(1643003697.595:490): prog-id=138 op=LOAD
[228183.668681] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[228183.668708] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[228183.668852] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[228183.669111] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[228183.669154] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[228183.669338] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[228183.669709] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[228183.669874] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[228183.669950] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[228183.694336] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[228183.694370] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[228183.694401] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[228183.694435] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[228183.694450] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[228183.694467] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[228183.694484] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[228183.694503] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[228183.694517] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[228213.429643] audit: type=1334 audit(1643003727.656:491): prog-id=136 op=UNLOAD
[228213.429657] audit: type=1334 audit(1643003727.656:492): prog-id=135 op=UNLOAD
[228213.965447] audit: type=1334 audit(1643003728.192:493): prog-id=138 op=UNLOAD
[228213.965457] audit: type=1334 audit(1643003728.192:494): prog-id=137 op=UNLOAD
[235783.980686] audit: type=1334 audit(1643011298.538:495): prog-id=139 op=LOAD
[235783.980809] audit: type=1334 audit(1643011298.538:496): prog-id=140 op=LOAD
[235784.319955] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[235784.320155] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[235784.320260] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[235784.320301] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[235784.320602] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[235784.320695] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[235784.320725] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[235784.321384] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[235784.321433] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[235784.339018] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[235784.339052] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[235784.339086] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[235784.339109] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[235784.339125] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[235784.339141] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[235784.339166] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[235784.339181] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[235784.339196] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[235784.576190] audit: type=1334 audit(1643011299.134:497): prog-id=141 op=LOAD
[235784.576226] audit: type=1334 audit(1643011299.134:498): prog-id=142 op=LOAD
[235784.857274] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[235784.857319] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[235784.857527] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[235784.858009] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[235784.858148] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[235784.858164] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[235784.858203] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[235784.858428] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[235784.858659] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[235784.879957] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modules-load.d supports timestamps until 2038 (0x7fffffff)
[235784.879981] ext4 filesystem being remounted at /run/systemd/unit-root/etc/modprobe.d supports timestamps until 2038 (0x7fffffff)
[235784.879997] ext4 filesystem being remounted at /run/systemd/unit-root/etc/docker supports timestamps until 2038 (0x7fffffff)
[235784.880018] ext4 filesystem being remounted at /run/systemd/unit-root/etc/systemd/timesyncd.conf supports timestamps until 2038 (0x7fffffff)
[235784.880033] ext4 filesystem being remounted at /run/systemd/unit-root/etc/dropbear supports timestamps until 2038 (0x7fffffff)
[235784.880048] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hosts supports timestamps until 2038 (0x7fffffff)
[235784.880065] ext4 filesystem being remounted at /run/systemd/unit-root/etc/udev/rules.d supports timestamps until 2038 (0x7fffffff)
[235784.880094] ext4 filesystem being remounted at /run/systemd/unit-root/etc/NetworkManager/system-connections supports timestamps until 2038 (0x7fffffff)
[235784.880108] ext4 filesystem being remounted at /run/systemd/unit-root/etc/hostname supports timestamps until 2038 (0x7fffffff)
[235814.649672] audit: type=1334 audit(1643011329.212:499): prog-id=140 op=UNLOAD
[235814.649683] audit: type=1334 audit(1643011329.212:500): prog-id=139 op=UNLOAD
[235815.121658] audit: type=1334 audit(1643011329.684:501): prog-id=142 op=UNLOAD
[235815.121670] audit: type=1334 audit(1643011329.684:502): prog-id=141 op=UNLOAD
