Hi all,
I am using HA for years. Sometimes I had some troubles when updates make my system hang, but normal HA works stable for at least some Months. But since some weeks, system hangs come up often.
I am using the latest Versions
- Core 2024.9.2
- Supervisor 2024.09.1
- Operating System 13.0
- Frontend 20240909.1
with a rpi3-64, Disk is a SSD. No Expansion Cards.
Addons
- zigbee2mqqt
- Mosquitto broker
- File Editor
And HACS
- Raspberry Pi 1-Wire via sysbus
- Local Tuya
- edl-21
I installed the developer SSH access. When the system hang up, there is no more response. No Ping, no SSH Access on Port 22222.
The journalctl give me no hints, so I ask if someone could help. Did you see something in my logs? What are my next debug Steps?
Here are some hangs: Bildschirmfoto-vom-2024-09-22-17-53-20 hosted at ImgBB — ImgBB
journalctl --list-boots
IDX BOOT ID FIRST ENTRY LAST ENTRY
-6 002e703fee05467f952ba3b18ecb05bd Sat 2024-08-31 17:57:30 UTC Sat 2024-08-31 22:14:27 UTC
-5 27160367a1bc4938abe2fe6fd5c746e6 Sat 2024-08-31 23:13:04 UTC Mon 2024-09-02 07:24:38 UTC
-4 55da6fa0c0d94ab88ffc9ec0e4bf9a2f Tue 2024-09-03 20:37:25 UTC Sat 2024-09-07 00:54:21 UTC
-3 c31329f3f4e3414d84a6db2f1278dc7e Tue 2024-09-10 12:20:21 UTC Thu 2024-09-12 23:51:48 UTC
-2 8070471fd0ea45d89114d641a6593464 Fri 2024-09-13 20:41:17 UTC Fri 2024-09-13 21:05:40 UTC
-1 66f927354939411eacf8f5f159655576 Sat 2024-09-21 16:27:46 UTC Sun 2024-09-22 06:50:01 UTC (power was switched off)
0 876291d0d4a246b28b5d260c80113ced Sun 2024-09-22 06:55:16 UTC Sun 2024-09-22 15:46:51 UTC
2024-09-17 16:35 (14:35 UTC)
journalctl --since "2024-09-17 16:00:00"
Sep 21 16:27:46 homeassistant systemd-time-wait-sync[502]: adjtime state 5 status 40 time Sat 2024-09-21 16:27:46.985550 UTC
Sep 21 16:27:46 homeassistant systemd-timesyncd[511]: System clock time unset or jumped backwards, restored from recorded time
Sep 22 06:48:32 homeassistant systemd-time-wait-sync[502]: adjtime state 0 status 2000 time Sun 2024-09-22 06:48:32.608025 UTC
Sep 21 16:27:46 homeassistant systemd-resolved[394]: Clock change detected. Flushing caches.
Sep 21 16:27:46 homeassistant systemd[1]: Started Network Time Synchronization.
Sep 22 06:48:32 homeassistant systemd-timesyncd[511]: Contacted time server 192.168.178.1:123 (192.168.178.1).
Sep 22 06:48:32 homeassistant systemd-timesyncd[511]: Initial clock synchronization to Sun 2024-09-22 06:48:32.607762 UTC.
Sep 22 06:48:32 homeassistant systemd-resolved[394]: Clock change detected. Flushing caches.
Sep 22 06:48:32 homeassistant systemd[1]: Finished Wait Until Kernel Time Synchronized.
Sep 22 06:48:32 homeassistant systemd[1]: Reached target System Time Set.
Sep 22 06:48:32 homeassistant systemd[1]: Reached target System Time Synchronized.
Sep 22 06:48:32 homeassistant systemd[1]: Started Discard unused filesystem blocks once a week.
Sep 22 06:48:32 homeassistant systemd[1]: Remove Bluetooth cache entries was skipped because of an unmet condition check (Cond
Sep 22 06:48:32 homeassistant systemd[1]: Reached target Timer Units.
Sep 22 06:48:32 homeassistant systemd[1]: Starting HassOS AppArmor...
Sep 22 06:48:32 homeassistant audit[525]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="hassio-sup
Sep 22 06:48:32 homeassistant kernel: audit: type=1400 audit(1726987712.725:14): apparmor="STATUS" operation="profile_load" pr
Sep 22 06:48:32 homeassistant kernel: audit: type=1300 audit(1726987712.725:14): arch=c00000b7 syscall=64 success=yes exit=393
Sep 22 06:48:32 homeassistant audit[525]: SYSCALL arch=c00000b7 syscall=64 success=yes exit=39339 a0=6 a1=55a4ce2e00 a2=99ab a
Sep 22 06:48:32 homeassistant audit: PROCTITLE proctitle=61707061726D6F725F706172736572002D72002D57002D4C002F6D6E742F646174612
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.736280145Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.736692645Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.737048999Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant systemd[1]: Finished HassOS AppArmor.
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.746264676Z" level=info msg="skip loading plugin \"io.
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.746476656Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.747805093Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.750385458Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.752646603Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.752997333Z" level=info msg="metadata content store po
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.834947333Z" level=info msg="loading plugin \"io.conta
Sep 22 06:48:32 homeassistant containerd[476]: time="2024-09-22T06:48:32.835271291Z" level=info msg="loading plugin \"io.conta
2024-09-18 13:10 (11:10 UTC) System Hang
journalctl --since "2024-09-18 11:00:00"
2024-09-21 18:27 (16:27 UTC) System Hang
journalctl --since "2024-09-21 18:00:00"
