The problem is that I can’t use a state (because it doesn’t have a value_template) nor a template (because it needs to return a boolean result) nor a numeric (below or above are required) trigger.
I came up with a workaround by creating a template sensor and using that entity as a state trigger. This works but I don’t like it for 2 reasons:
Can’t create a blueprint out of it (or: it is not reusable)
Configuration needs to be changed to adjust the values
Question Is it possible to trigger an automation based on such a template so I can have everything inside the automation?
That is what I started with, however this won’t work for me since I can’t set the for: property:
I only want to change the fan speed when the humidity is in a range for a certain period. (For example, adjust fan speed to when humidity is medium for 5 minutes) the last part does not work since the humidity often fluctuates.
In the meantime I decided that it needs to be a bit smarter than that, the humidity should take into consideration that the thresholds also change, it should look at the deviation from the average in the same room (over the last 24 hours or so).
So I thought about it and now I think that I want the fan to be at medium when humidity is 10% higher than it was on average over the last 24 hours, and on high when it is 20% higher. (actual numbers to be decided).
Solved it by creating a statistics sensor with max_age of 24 hours and a template sensor that converts the statistics change attribute to fan percentages. No I only have a simple automation left that triggers on the template sensor state (with a for condition) which sets the actual fan sensor.
