In post #1 I wrote about the mailbox: a camera and an AI that tell us whether the mail really came. This one is its twin at the other end of the driveway, the trash can. Same idea, a different question, and a new set of wrong notes.
A quick reminder of how we work: our house runs on Home Assistant, kept local wherever we can, and I build it with an AI assistant (Claude) as a working partner. Nothing is trusted until it has been rehearsed.
The problem: was it picked up, or not?
Our trash can goes out to the end of a long driveway the evening before pickup. From the house you can’t see whether it has been emptied, and you don’t want to walk down and lift the lid to find out. If the truck skips you, you want to know that day, not a week later when the can is overflowing.
The hauler uses a big green truck with a side arm. It pulls up, grabs the can, tips it into the back and sets it down. The can is much bigger than a mailbox and the truck is huge, so this looked like an easier job for a camera than the mail was.
What we built: when the can moves, look
A small vibration sensor rides inside the top of the can body (not the lid, which flaps in the wind). Here is what happens when it feels a bump:
- The same two driveway cameras the mailbox check uses each take four pictures, 3 seconds apart. Eight pictures, so a truck driving past on the highway doesn’t look like a truck that stopped.
- Home Assistant sends the eight pictures to Claude through its AI Task feature, the same model and the same top thinking level as the mailbox check. The question is plain: is a large garbage truck stopped at the can, collecting it? It also asks: can you see the can at all, and where is it? Is anyone on foot near it?
- The answer comes back as a verdict (truck or no truck), a confidence level, and one descriptive sentence.
- My phone gets a push with the verdict in the title, the sentence as the message, and one of the pictures attached.
- Once it sees the truck with high or medium confidence, it marks the trash as picked up and stops checking until next week. An empty can rocking in the wind doesn’t keep calling the AI.
It only listens on pickup day, from 6 AM to 6 PM, and it ignores bumps while the sprinkler zone that sprays the can is running. This morning it took 99 seconds from the can moving to the phone buzzing.
The wrong notes, and how we fixed them
Pickup comes once a week, so every rehearsal takes seven days. We skipped the usual week of watching first and tested it on the real thing from day one.
- The rain spent our money. The first week, the check listened from noon the day before pickup. It rained that night, and the can shook 23 times before the truck came the next morning. Every shake was an AI check, and 18 of them came before 6 AM. Each check costs a little, and a can shaking in the rain in the middle of the night tells us nothing about a truck. We cut the window to pickup day, 6 AM to 6 PM. The cost: a truck before 6 AM would be missed. The earliest I have ever seen ours is 8:30.
- The push stopped mid-word. The first real pickup was caught correctly, and the description was spot on. But the notification ended “…on f” and read as if something was missing. We counted from a screenshot: my phone shows 256 characters of the message and then stops dead. The assistant’s first fix cut the AI to 20 words. I liked the detail, so that was the wrong fix. Now the verdict rides in the title, the AI may use up to 40 words but must stay under 240 characters, and if it ever runs long the push ends on a whole word.
- The truck took a holiday, and the house couldn’t know. Last week a federal holiday pushed pickup back a day. The check looked twice that morning and correctly said “no truck” both times. By afternoon the records could not tell “the truck hasn’t come” from “the truck came and the sensor missed it.” Only my knowing about the holiday settled it. We stretched the window one extra day for that week, and it goes back to normal tonight. The house reads the cameras well. It does not read the hauler’s holiday schedule.
Where it stands, and the next rehearsal
This morning was the holiday-shifted pickup, and it went the way it should:
- 8:52 AM, a truck that wasn’t the trash truck. The can shook while a white box truck was parked up by the house. The AI said no garbage truck at the can, the can standing alone at the road, and described the box truck at the house. A truck in the picture, correctly not counted.
- 10:07 AM, the real thing. The can moved at 10:05 and my phone buzzed 99 seconds later: “A large green garbage truck is stopped at the left end of the driveway in all eight photos, the can apparently gripped by its orange side arm.” High confidence, with the picture attached.
- 10:22 AM, nothing. The can shook again 15 minutes later. Pickup was already marked done, so no check ran and nothing was spent.
The pushes still come only to my phone while we test. One piece still leans on the cloud: the vibration sensor in the can reports through its maker’s hub, the same as the mailbox’s did. If the local Zigbee sensor now on trial in the mailbox earns its keep, the trash can is next in line. That will be a future note.
Readers of post #1 asked a fair question: why not a sensor that reads tilt? On trash day that is tempting, because the truck’s arm turns the can completely upside down, and wind and rain never do. The catch is keeping the sensor. Anything on the lid, or even stuck inside the can, gets turned upside down and shaken over the truck every week. If it lets go, it ends up in the back of the truck or on the road as the truck drives away. So before we trust tilt, the sensor has to be mounted where a weekly dump can’t knock it loose. That is a rehearsal still to come.
Your turn
Do you track trash pickup at all? A sensor on the can, a camera, your hauler’s app, or just a look out the window? If you send camera pictures to an AI, how do you keep the cost down when wind and rain set things off? And has anyone found a way to teach Home Assistant the hauler’s holiday schedule? I would love to hear what worked for you, and what didn’t.
Next in the series: whatever we finish rehearsing next at Bell House.
