Maybe i am forced to reinstall from scratch Hassbian.
To not loose anything may i, (after installation), copy over the new my old config files? Also the database and all the folder i saved?
Please help me in this as i am new to reinstallation…
Just as you suggested all you need to copy is the configuration and potentially your database file.
At first boot Hassbian will boot with the default configuration.
Then you need to stop Home Assistant, replace your configuration and restart Home Assistant.
