Reinstalled hadashboard v3 and now no entity_id are not recognized
Can’t see what is wrong
appdaemon:
  cert_verify: False
  logfile: STDOUT
  errorfile: STDERR
  threads: 10
  app_dir: /config/appdaemon/apps
  plugins:
    HASS:
      type: hass
      ha_url: xxx.duckdns.org   #TRIED ALSO PUTTING https://
      ha_key: pi3
      cert_path: /ssl
      cert_verify: True
      namespace: default
hadashboard:
  dash_url: http://127.0.0.1:5050
  dash_dir: /config/appdaemon/dashboards
  rss_feeds:
    - feed: http://rss.cnn.com/rss/cnn_topstories.rss
      target: news
  rss_update: 300
log
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing…
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 03-version-requirements.sh: executing…
INFO: Supervisor version requirements checks passed.
[cont-init.d] 03-version-requirements.sh: exited 0.
[cont-init.d] 20-init-configuration.sh: executing…
[cont-init.d] 20-init-configuration.sh: exited 0.
[cont-init.d] 21-compiled-dir.sh: executing…
[cont-init.d] 21-compiled-dir.sh: exited 0.
[cont-init.d] 50-compiled-symlink.sh: executing…
[cont-init.d] 50-compiled-symlink.sh: exited 0.
[cont-init.d] 80-system-packages.sh: executing…
[cont-init.d] 80-system-packages.sh: exited 0.
[cont-init.d] 81-python-packages.sh: executing…
[cont-init.d] 81-python-packages.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
starting version 3.2.4
[services.d] done.
2018-02-05 12:29:52.841424 INFO AppDaemon Version 3.0.0b2 starting
2018-02-05 12:29:52.841772 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-02-05 12:29:52.842906 INFO AppDaemon: Starting Apps
2018-02-05 12:29:52.845074 ERROR AppDaemon: Invalid value for app_dir: /config/appdaemon/apps
2018-02-05 12:29:52.845279 INFO Starting Dashboards
2018-02-05 12:29:52.863675 INFO API is disabled
2018-02-05 12:29:53.163334 INFO HADashboard: New dashboard connected: Main Panel
2018-02-05 12:29:53.180667 INFO HADashboard: New dashboard connected: Media Panel
2018-02-05 12:29:54.645044 INFO HADashboard: New dashboard connected: Media Panel
now work, but I think crashes all the time …
2018-02-05 12:49:19.800702 INFO AppDaemon: HASS: Connected to Home Assistant 0.62.1
2018-02-05 12:49:20.081110 INFO HADashboard: New dashboard connected: Main Panel
2018-02-05 12:49:20.233356 INFO AppDaemon: Got initial state from namespace default
File “/usr/bin/appdaemon”, line 11, in
sys.exit(main())
File “/usr/lib/python3.6/site-packages/appdaemon/admain.py”, line 341, in main
admain.main()
File “/usr/lib/python3.6/site-packages/appdaemon/admain.py”, line 337, in main
self.run(appdaemon, hadashboard)
File “/usr/lib/python3.6/site-packages/appdaemon/admain.py”, line 79, in run
loop.run_until_complete(asyncio.gather(*pending))
File “/usr/lib/python3.6/asyncio/base_events.py”, line 467, in run_until_complete
return future.result()
File “/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py”, line 1292, in utility
await utils.run_in_executor(self.loop, self.executor,self.read_apps, True)
File “/usr/lib/python3.6/site-packages/appdaemon/utils.py”, line 121, in run_in_executor
response = list(completed)[0].result()
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py”, line 1843, in read_apps
mod[“priority”] = self.get_app_priority(mod[“name”])
File “/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py”, line 1735, in get_app_priority
for name in self.app_config:
TypeError: ‘NoneType’ object is not iterable
2018-02-05 12:49:32.245270 INFO AppDaemon Version 3.0.0b2 starting
2018-02-05 12:49:32.245548 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-02-05 12:49:32.246461 INFO AppDaemon: Starting Apps
2018-02-05 12:49:32.267137 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-02-05 12:49:32.370849 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-02-05 12:49:32.371392 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-02-05 12:49:32.371702 INFO Starting Dashboards
2018-02-05 12:49:32.378696 INFO API is disabled
2018-02-05 12:49:32.614039 INFO AppDaemon: HASS: Connected to Home Assistant 0.62.1
2018-02-05 12:49:32.752031 INFO function [get_dashboard] finished in 48 ms
that can happen when you leave dashboards open when you reinstall.
first close everything and the restart the device with appdaemon and THEN startup the dashboards.
Done that,
Now I have
Err connection refused
Err connection reset
Loading but with error getting state java control .
Then fine
Then again Error connection refused and so on
A restart or a reboot?
in doubt always reboot.
and you need to put the https:// back first.
Ok some progress, now I have only
Edit, appdaemon is not starting in HASSIO, ver 3
Edit actually having same behavior as before, cyclical all sorts of errors
Some new errors in log
2018-02-05 13:45:03.321329 INFO AppDaemon: HASS: Connected to Home Assistant 0.62.1
2018-02-05 13:45:05.316949 ERROR AppDaemon: Required attribute not set or obtainable from any plugin: latitude
2018-02-05 13:45:05.317215 ERROR AppDaemon: AppDaemon is terminating
close status: 31522
2018-02-05 13:45:05.318176 ERROR AppDaemon: Required attribute not set or obtainable from any plugin: longitude
2018-02-05 13:45:05.318351 ERROR AppDaemon: AppDaemon is terminating
2018-02-05 13:45:05.318591 ERROR AppDaemon: Required attribute not set or obtainable from any plugin: elevation
2018-02-05 13:45:05.318692 ERROR AppDaemon: AppDaemon is terminating
2018-02-05 13:45:05.318801 ERROR AppDaemon: Required attribute not set or obtainable from any plugin: time_zone
2018-02-05 13:45:05.318894 ERROR AppDaemon: AppDaemon is terminating
2018-02-05 13:45:06.122706 INFO AppDaemon: HASS: Disconnecting from Home Assistant
2018-02-05 13:45:27.572850 INFO function [get_dashboard] finished in 53 ms
2018-02-05 13:45:29.200058 INFO HADashboard: New dashboard connected: Main Panel
2018-02-05 13:45:32.260144 INFO function [get_dashboard] finished in 45 ms
2018-02-05 13:45:32.283477
I think it crashes, reboots works for few seconds and then crashes again
Logs
2018-02-05 13:52:01.589490 INFO Starting Dashboards
2018-02-05 13:52:01.608853 INFO API is disabled
2018-02-05 13:52:01.773221 INFO AppDaemon: HASS: Connected to Home Assistant 0.62.1
2018-02-05 13:52:02.293276 INFO AppDaemon: Got initial state from namespace default
sys.exit(main())
admain.main()
2018-02-05 13:52:06.159110 INFO AppDaemon Version 3.0.0b2 starting
2018-02-05 13:52:06.159440 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-02-05 13:52:06.160646 INFO AppDaemon: Starting Apps
2018-02-05 13:52:06.197817 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-02-05 13:52:06.315291 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-02-05 13:52:06.318297 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-02-05 13:52:06.318727 INFO Starting Dashboards
2018-02-05 13:52:06.325831 INFO API is disabled
2018-02-05 13:52:06.612138 INFO AppDaemon: HASS: Connected to Home Assistant 0.62.1
2018-02-05 13:52:07.262957 INFO AppDaemon: Got initial state from namespace default
sys.exit(main())
admain.main()
2018-02-05 13:52:10.446314 INFO AppDaemon Version 3.0.0b2 starting
2018-02-05 13:52:10.446611 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-02-05 13:52:10.447547 INFO AppDaemon: Starting Apps
2018-02-05 13:52:10.468119 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-02-05 13:52:10.570259 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-02-05 13:52:10.571033 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-02-05 13:52:10.571313 INFO Starting Dashboards
2018-02-05 13:52:10.578078 INFO API is disabled
2018-02-05 13:52:10.823362 INFO AppDaemon: HASS: Connected to Home Assistant 0.62.1
2018-02-05 13:52:11.228411 INFO AppDaemon: Got initial state from namespace default
sys.exit(main())
admain.main()
2018-02-05 13:52:21.623184 INFO AppDaemon Version 3.0.0b2 starting
2018-02-05 13:52:21.623519 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-02-05 13:52:21.624677 INFO AppDaemon: Starting Apps
2018-02-05 13:52:21.641767 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-02-05 13:52:21.788169 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-02-05 13:52:21.788600 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-02-05 13:52:21.788838 INFO Starting Dashboards
2018-02-05 13:52:21.799495 INFO API is disabled
2018-02-05 13:52:21.890263 INFO AppDaemon: HASS: Connected to Home Assistant 0.62.1
2018-02-05 13:52:22.463007 INFO AppDaemon: Got initial state from namespace default
back to appdaemon v2 … sigh
Do you really have to use the external dns name of your HA?
Nothing like http://127.0.0.1:8123?
I just set up v3 and it’s working fine.
i think you got an apps.yaml in the config dir that is wrong.
