HA Build: 2022.2.3 WP By Alex… Alexx??
OS : Windows 10
Network : Samsung Smartthings 3rd gen Wifi 3 nodes all ethernet connected
Comp: Lenovo i7 5th Gen x64
Before asked yes I accessed DOS and turned on virtual machine option for Lenovo
First off… Sorry if this has been mentioned, discussed, discovered, or a solution found already. It could be that I’m inadept enough to not understand what it is I am doing.
I have successfully installed home assistant on 2 CPU’s, the first one didn’t have the processing power (it’s an older AMD processor) to fully utilize it. So I reinstalled it on a newer PC, the one mentioned above. Unfortunately, EVER time I restart the CPU or close the browser window with HA on it I can no longer access it! For Clarification purposes it pops up with “This site can not be reached… blah blah blah”.
I have tried “http://homeassistant.local:8123” & also “https://homeassistant.local:8123” I also read somewhere (probably on one of these threads) it can also be accessed from the host IP I.E. “192.168.0.0:8123”, which all came to no avail. I went into the config/.storage file at 1 point & deleted all the AUTH files to access HA to see if that would allow it to pop up & still nada. The only way I can access it is by re running the software mentioned above and reinstalling it! The initial install took quite a while, but now when I run it, it goes through a portion of the initial install then it boots right back up! The issue is it needs to rediscover devices & needs me to reinput all relevant information, basically it’s a fresh install! I also install the android app on my Galaxy S21 Ultra, but can not access it from there either.
Any and all help would be greatly appreciated,
Signed: Seriously Frustrated
