Hi, I have a component that counts active switches:
sensors:
count_switch:
friendly_name: 'Switch attivi'
unique_id: switch_attivi111
value_template: "{{ states.switch | selectattr('state', 'eq', 'on') | rejectattr('entity_id','in',('switch.shelly_em', 'switch.luce_divano', 'switch.luce_cucina', 'switch.luce_tavola', 'switch_scheduler')) | list | count }}"
Is there a way to exclude all the switches of an integration (xiaomi)? I inserted a robot vacuum cleaner that has 20…
123
(Taras)
July 3, 2024, 2:58pm
2
If the integration’s name is xiaomi
then you can use the integration_entities
function to get list off all its entity_ids. Then you can select only the one containing switch
value_template: >
{% set rejects = ['switch.shelly_em', 'switch.luce_divano', 'switch.luce_cucina', 'switch.luce_tavola', 'switch_scheduler'] %}
{% set xiaomi_rejects = integration_entities('xiaomi') | select('match', 'switch') | list %}
{{ states.switch
| rejectattr('entity_id', 'in', rejects)
| rejectattr('entity_id', 'in', xiaomi_rejects)
| list | count }}
it doesn’t work… this is the integration
Code:
value_template: >
{% set xiaomi_rejects = integration_entities('xiaomi_robot_vacuum_x20') | select('match', 'switch') | list %}
{{ states.switch | rejectattr('entity_id', 'in', rejects) | rejectattr('entity_id', 'in', xiaomi_rejects) | selectattr('state', 'eq', 'on') | list | count }}
Troon
(Troon)
July 8, 2024, 8:03am
4
What is the URL of that screenshot? It should look like:
http://IP:8123/config/integrations/integration/xxxxxx
The integration name will be the xxxxxx
at the end of it — put that into the integration_entities
function.
123
(Taras)
July 8, 2024, 2:45pm
5
millenniumy2k:
it doesn’t work
In your first post you said the integration’s name is xiaomi
However, if the suggested template doesn’t work then it means the integration’s name is not xiaomi
but something else.
Replace the word xiaomi
in:
with the integration’s actual name. It might be dreame_vacuum
if you’re using this custom integration .
integration_entities('dreame_vacuum')
Troon’s post shows one way of determining the actual name.
