Hello together,
I’m searching a wifi relay with 4 contacts (could also be 2 relais with two contacts each), to switch on and of my heatpump beacuse I want to control it with the home assistant Thermstat.
I know there are many relais availble (e.g. Shelly Uni), but I would neet a relay with a input voltage of 5 VDC that works together with Home assistant. Another possibility would be a 230V DC relay
Do you have any suggestions what to choose ?
Greets Karl
