Related entities missing
Hello everybody,
I use all kinds of notification services in a various number of automations. To keep an overview, I created a script that manages the different notification types. This way I could track where the script is used.
I was quite disillusioned, when I discovered that no related automations were displayed in the ‘more info’ dialogue. I then checked other scripts with the same result. Only two scripts show in which automations they are used.
Before I raise an issue on Github, I would like to hear other opinions on whether it might be my scripts themselves or I’m making a mistake in thinking.
Script where related automations are displayed:
alias: "[Alarm] Blinklicht"
variables:
  l: >-
    {{ states.light
    |rejectattr('attributes.entity_id', 'defined')
    |rejectattr('attributes.hue_type', 'defined')
    |rejectattr('entity_id', 'in', ['light.ankleide',
    'light.hue_smart_plug_0b96e1'])
    |map(attribute='entity_id') |list }}
sequence:
  - service: light.turn_on
      entity_id: "{{ l }}"
      brightness_pct: 100
      rgb_color:
        - 255
        - 0
        - 0
  - delay:
      seconds: 2
  - service: light.turn_off
  - service: script.turn_on
      entity_id: script.alarm_loop
Without:
alias: notify_services
description: |-
  zentrale Verwaltung aller 'notify' service calls
  packages/skripte/notify_service.yaml
variables:
  service: dötchen
  service_source: >-
    {{- service |replace('alexa', 'alexa_media') |replace('last',
    'alexa_media_last_called') |replace('dötchen', 'alexa_media_echo_dotchen')
    |replace('show', 'alexa_media_echo_show') |replace('google',
    'google_nest_mini') |replace('persist', 'persistent_notification')
    |replace('push', 'push_benachrichtigungen') |replace('sprache',
    'sprach_benachrichtigungen') -}}
  target: >-
    {{ 'media_player.echo_' ~ service if service in ['dotchen', 'show'] else
    'group.echos' }}
  title: ""
  message: notify
  type: tts
sequence:
  - if:
      - "{{ 'alexa' in service_source }}"
    then:
      - service: notify.{{ service_source }}
          title: "{{ title }}"
          message: "{{ message }}"
          target: "{{ target }}"
            type: "{{ type }}"
    else:
I am happy to receive any kind reply.
Ok, script 1 is called by script.turn_on, script 2 not. After changing the service call, script 2 displays correctly, which automation it is part of. I will raise an issue.
