I would like to use a temperature sensor above my stove to measure a relative temperature difference to turn the kitchen fan on/off, see pic.
Any suggestions on how to achieve this?
It has to be relative because I don’t have airconditioning and the room temperature in winter and summer can be quite different.
One way is to create a template sensor that calculates the temperature difference. Then make automations that switch the fan on or off using a numerical state trigger that monitors this difference.
sensors:
temperature_difference:
friendly_name: "Temperature Difference"
unit_of_measurement: '°C'
value_template: >
{{ states('sensor.stove_top_temp_sensor_here')|float - states('sensor.room_temp_sensor_here')|float }}
Automations:
alias: stove_fan_on
platform: numeric_state
entity_id: sensor.temperature_difference
above: 10
service: switch.turn_on
entity_id: switch.stove_fan
alias: stove_fan_off
below: 5
service: switch.turn_off
You would have to reload automations (rather than restart) if fine tuning the trip points. If that is too much hassle you could create a couple of input numbers for the on and off trip point temperature differentials. The automation triggers would then have to be template triggers. But honestly once you get the values right I don’t see it changing much so it’s probably not worth the hassle.
Thank you very much! That did it
Just came across this and I am using it successfully to turn on a ceiling fan. Sometimes the temperature difference is expressed in 15 decimal places though! How could I make it display in just one or two decimals?
Thanks.
{{ ( states('sensor.stove_top_temp_sensor_here')|float(0) - states('sensor.room_temp_sensor_here')|float(0) )|round(2) }}
Perfect, thank you.
Thank you very much. I used the template to evaluate the difference between the wall thermostat and a Tasmota thermostat on the fire stove to control whether a window must be opened before the cooker hood can be used.
I have created a sensor. But how can I chart the results in history graph?
My sensor is:
template:
- binary_sensor:
- name: temp_diff_gh
value_template: >
{{ states('sensor.0x60a423fffe3c5d9b_temperature')|float - states('sensor.0xa4c138ec379fb0d6_temperature')|float }}
Hi, im trying to get the following to work for hours now, but dont know what is wrong, keep telling me Message malformed: extra keys not allowed @ data['0']
Can anyone please help.
- alias: Pomp WP wisselaar in en uitschakelen
platform: template
sensors:
friendly_name: Temperature Difference
unit_of_measurement: °C
value_template: >
{{ ( states('sensor.tasmota_basic_ds18b20_ds18b20_temperature')|float(0) - states('sensor.thr316d_ht1_ds18b20_temperature')|float(0) )|round(2) }}
alias: pommp aan
above: 10
entity_id: switch.4ch_ht8_pomp_hottub_ww_warmtepomp
alias: pomp uit
below: 5
This whole sensor definition does not belong in your automaton configuration.
Put this in your configuration.yaml file, do a config check then if that passes restart home assistant:
template:
- sensor:
- name: Temperature Difference
device_class: temperature
state_class: measurement
state: >
availability: >
{{ has_value('sensor.tasmota_basic_ds18b20_ds18b20_temperature') and has_value('sensor.thr316d_ht1_ds18b20_temperature') }}
Then write your two automations (in yaml or using the UI):
above: 10
alias: pomp uit
below: 5
Hi Tom
Thx it works, j never realised I had to creatie a difference sensor its clear now
I have 1 order thing.
I only want to heat sertain times, but when the temp is alraidy below the trigger point the heater wont trigger
Is need a trigger wich not only trigger on the setpoint switch but also everything below
Is that possible?
The trick is not in the setpoint trigger, but to also add a time trigger for the start time. And you should duplicate the temperature test in the conditions.
Hi Edwin
Thx for the reply
Id dit i gues, but again no heating this morning
Can you see what I did worg?
alias: Badkamer - verwarming 20 graden
description: ""
- platform: numeric_state
entity_id:
- sensor.th16_bk1_si7021_temperature
above: 20
enabled: true
entity_id:
below: 19.5
condition:
- condition: time
after: "08:00:00"
weekday:
- sun
- sat
before: "10:00:00"
enabled: true
- condition: time
after: "20:00:00"
weekday:
- sun
- sat
before: "23:30:00"
enabled: true
- condition: time
before: "16:00:00"
after: "07:00:00"
weekday:
- mon
- tue
- wed
- thu
- fri
enabled: true
- condition: time
before: "23:30:00"
after: "21:30:00"
weekday:
- mon
- tue
- wed
- thu
- fri
enabled: true
- choose:
- conditions:
- condition: trigger
id:
- Badkamer 20+
sequence:
- service: switch.turn_off
data: {}
entity_id: switch.th16_bk1_badkamer_verwarming
- service: notify.mobile_app_iphone_van_henk
message: Badkamer verwarming uit
title: Melding
- conditions:
id:
- Badkamer 20-
sequence:
- service: switch.turn_on
data: {}
message: Badkamer verwarming aan
title: Melding
mode: single
What I said. the only moments that this is automation is evaluated is when the temperature crosses a threshold. If the time conditions block it, nothing happens. So, instead of just temperature triggers and time conditions, you also need time triggers and temperature conditions. You want it to check at the start of the time block what the temperature is.
I would also introduce a schedule helper entity (create one in the helpers section). It would greatly simplify the automation. Alternatively you could use a local calendar entity if some weeks are different than others.
Hi Edwin.
oke, so this will work then?`
or would you advise me to add extra triggers
description: ""
- platform: state
entity_id:
- schedule.badkamer_verwarming_aan
to: "on"
- platform: state
entity_id:
to: "off"
condition:
- type: is_temperature
condition: device
device_id: 04cd8782f6dcc41f19fdac6384a2ed62
entity_id: e8f72faa0ce2bce9da2473f3946b9e19
domain: sensor
below: 20
- choose:
- conditions:
id:
- schema uit
sequence:
data: {}
title: Melding
- conditions:
id:
- Schema aan
sequence:
data: {}
title: Melding
mode: single
This would do the situations you missed beforehand, but would then miss temperatures dropping while the schedule is already on. So you also need the original triggers you had for temperatures crossing thresholds. Those were fine - you need both as triggers.
There is a threshold entity for that as well in the helpers section by the way, I use them a lot. They create a binary sensor that goes on or off when the numerical state is outside bounds. I’d recommend that too - it is a matter of taste what you like best.
Always when you have multiple conditions that need to be true for something to happen, then you need multiple triggers to look for the corresponding changes too. So HA needs to check both when the schedule changes and when the temperature changes (triggers), and then use both the state of the schedule and the temperature to decide what to do.
Oke Edwin,
I start working on that
One more question if i may
Ik have added a second template sensor but its not showing afther restart
What is wrong?
this one: Temp verschil solarkoepel uit-hottub
template:
- sensor:
- name: "Temp verschil wp wisselaar-hottub"
unit_of_measurement: "°C"
device_class: "temperature"
state_class: "measurement"
state: >
availability: >
- name: "Temp verschil solarkoepel uit-hottub"
state: >
{{ ( states('sensor.thr316d_ht4_ds18b20_temperature')|float(0) - states('sensor.thr316d_ht1_ds18b20_temperature')|float(0) )|round(2) }}
availability: >
{{ has_value('sensor.thr316d_ht4_ds18b20_temperature') and has_value('sensor.thr316d_ht1_ds18b20_temperature') }}
found the example here:
oke i think i have it like this right?
description: ""
- platform: state
entity_id:
to: "on"
- platform: state
entity_id:
to: "off"
- platform: state
entity_id:
- binary_sensor.temperatuur_badkamer
to: "off"
id: Temperatuur schema Badkamer uit
- platform: state
entity_id:
- binary_sensor.temperatuur_badkamerv
to: "on"
id: Temperatuur schema Badkamer aan
condition:
condition: device
domain: sensor
below: 20
- choose:
- conditions:
id:
- schema uit
- Temperatuur schema Badkamer uit
sequence:
data: {}
title: Melding
- conditions:
id:
- Schema aan
- Temperatuur schema Badkamer aan
sequence:
data: {}
title: Melding
mode: single
As for the template sensors in your previous post, I see no obvious reason why they would be wrong. Do the logs say anything?
As for your new automation:
The triggers look fine.
The condition I’m not so sure. If the temp is above 20 the automation never does anything. Also not turn the heating off. That seems wrong to me. I think this condition should move to the appropriate choices.
Personally (but I know I’m one of few here looking at all examples you find in the forum) I’d make two automations. One to turn the heating on, one to turn it off. Most people want it together in one automation, but usually it makes stuff way more complicated because, as you see here as well, you need a choose or an if to separate the two actions.
The condition can stay the way it is if you only dedicate the automation to turning the heating on. In pseudocode (because I’m currently not in a position to write actual code easily):
The heating on automation:
- schedule turns on
- temperature drops to below threshold
condition:
- temperature is low
- schedule is on
- turn heating on
The heating off version:
- schedule turns off
- temperature rises above threshold
- turn heating off
Personally I think this is way easier to read and understand, and less code. And every automation has a single purpose.
And one last tip: stay away from device triggers and conditions. Use (numeric) state instead. If you ever change the sensor you’ll be much happier.
Hi Edwin,
Thank you so mutch for all the help!
After reading your trigger i manished to put it in one automation as follows.
description: ""
- platform: state
entity_id:
to: "on"
id: Tijd om te verwarmen
- platform: state
entity_id:
to: "off"
id: Tijd om niet te verwarmen
- platform: state
entity_id:
to: "off"
- platform: state
entity_id:
to: "on"
condition: []
- choose:
- conditions:
- condition: or
conditions:
id:
- Tijd om niet te verwarmen
- Badkamer warm
sequence:
data: {}
title: Melding
alias: Verwarming uit
- conditions:
- condition: or
conditions:
id:
- Tijd om te verwarmen
- Badkamer koud
sequence:
data: {}
title: Melding
alias: Verwarming aan
mode: single
I meshed up the condition bij using ‘and’ but it should be ‘or’
i think its oke now, it gives me a cleaner result to have it in 1 automation i think
Have yourself a good weekend
ps:
My template works now as well
I`m pretty happy with the last one, even when 1 of both temp sensors drop out the avarage sensor continue to work, it a very important one and it should
# Temp verschil tussen hottub en WP wisselaar
- sensor:
state: >
availability: >
# Temp verschil tussen hottub en solarkoepel uit
state: >
availability: >
- name: "Temp verschil solarkoepel-hottub"
state: >
{{ ( states('sensor.thr316d_ht3_si7021_temperature')|float(0) - states('sensor.thr316d_ht1_ds18b20_temperature')|float(0) )|round(2) }}
availability: >
{{ has_value('sensor.thr316d_ht3_si7021_temperature') and has_value('sensor.thr316d_ht1_ds18b20_temperature') }}
# Gemiddelde kachel temperatuur van kachel temp 1 en 2 kan zelfs 1 vande 2 uitvallen en word dan ignored
- name: "Gemiddelde kachel temp"
unique_id: sensor.gemiddelde_kachel_temp
state: >
{% set t = [states('sensor.thr316d_ht2_ds18b20_temperature'), states('sensor.th16_ht7_ds18b20_temperature')]
| reject('eq', 'unavailable') | map('float') | list %}
{% set qty = t|count %}
{{ (t|sum/qty)|round(1) if qty > 0 else states('sensor.gemiddelde_kachel_temp') }}
