Relay Controller w/ physical dimmer
Hello, I am new to Home Assistant and am looking to control my lights using HA. I had a few different routes I was planning on going down, but I am currently looking at relays to see if they would work for my setup. I am thinking about installing regular recessed lighting, which would be controlled by both HA and my physical dimmer switch. It is a toggle switch with a dimmer slider to the right of it. I was looking at something like the Aeotec Nano Dimmer (Nano Dimmer – Aeotec), and was wondering if this would work for what I am aiming to acheive. Ideally, I’d like to be able to control dimming and turning the light on/off from both HA and the physical switch. Also, if I were to install a relay, would the power to the light be completely cut, or would I still be able to say turn on the lights with a voice command if the switch is off? If there are alternative suggestions that work better, I’d be more than happy to hear them.
