Relays and SN74HC595: boot problem
I’m using an ESP32 board with two daisy chained SH74HC595 shift registers to control 16 relays. Relays are “modules” with active low, in other words low signal from the controller turns each relay on.
My problem is that during power-up the register sets outputs to low hence turning on the relays. They don’t just click, but stay on. The relays have restore_mode: ALWAYS_OFF set. Output enable pin (OE) has pull-up resistor and is controlled in the code. That works well when reset is triggered but on full power cycle the relays always turn on.
My idea was to use on_boot code:
esphome:
  on_boot:
    priority: -100.0
    then:
      - switch.turn_off: pin_10     # test relay set HIGH
      - delay: 10ms
      - switch.turn_on: oe_pin   # OE pin pulled LOW = active
      - logger.log: "Switched on, boot"
But it doesn’t behave as expected - pin_10 stays low and the relay turns on. I know that the oe_pin gets activated because without that command relays would be uncontrollable. There is no entry in the log (not sure if it should be though).
Working, but not clean solution was to add switch for oe_pin in every relay-related command. Is there a better way to achieve high outputs on shift register after boot?
Relevant part of the code is:
sn74hc595:
  - id: 'output_raz'
    data_pin: 16      #SER
    clock_pin: 17     #SRCLK
    latch_pin: 18     #RCLK
    sr_count: 2
switch:
  - platform: gpio
    pin:
      sn74hc595: output_raz
      number: 9
      inverted: true
      mode:
        output: true
  - platform: gpio
    pin:
      number: 19
      inverted: true
      mode:
        output: true
    restore_mode: ALWAYS_ON
To answer my own question: the reset pin on shift register (SRCLR) was floating. After adding a pull-up resistor, the startup is much more stable (or predictive).
However due to type of attached equipment I left the software switch (OE enable on every command).
