I’m trying to create a switch board with 4 relays and momentary switches. But after configuration, 2 relays are working but 2 relays are not turning on but their light indicators are turning on. Is it a voltage issue? or circuit issue? I’m using a d1mini connected to 5V 4 channel relay board powered by Hi-Link power supply 5V-0.6A (3 watts).
my ESPhome yaml,
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "xx"
password: "xx"
fast_connect: true
# Optional manual IP
manual_ip:
static_ip: 192.xxx.xx.xx
gateway: 192.xxx.xx.x
subnet: 255.xxx.xxx.x
ap:
ssid: "xx"
password: "xx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
# Relays
switch:
- platform: gpio
icon: 'mdi:lightbulb'
pin:
number: D1
# One of INPUT, INPUT_PULLUP or OUTPUT
mode: OUTPUT
inverted: True
- platform: gpio
name: "Bathroom Exhaust Fan"
icon: 'mdi:fan'
pin:
number: D2
mode: OUTPUT
inverted: True
- platform: gpio
icon: 'mdi:water-boiler'
restore_mode: RESTORE_DEFAULT_OFF
pin:
number: D4
mode: OUTPUT
inverted: True
- platform: restart
name: "Bathroom Panel REBOOT"
# Switches
binary_sensor:
- platform: gpio
pin:
number: TX
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: relay1
internal: True
- platform: gpio
pin:
number: RX
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: relay2
internal: True
- platform: gpio
pin:
number: D7
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: relay4
internal: True
I’ve tested wit 4 channel, relay 3 is working. But as I don’t need 4 relays, only need 3, I’m trying to resolve the issue that happened to those 2 relays not working.
