Release notes for April 25, 2015
It’s been a month since the latest update and a lot has happened again. Here a quick overview of the new things.
Line Charts James has upgraded the history in the frontend to support line graphs. Line graphs will be shown for any entity that has a unit of measurement. The line graphs will also be shown in the more info card of an entity. See the demo for a live example.
![](upload://q7x89EJ1iNO4Qrd9t8F3KjFhhzT.png)
ISY994 hub support ![](upload://uaKLGRA9FSpymcBmOQeB5dZIry7.png) Ryan has contributed support to integrate the ISY994 hub by Universal Devices. This allows you to integrate your X10/Insteon sensors, switches and lights.
He has created an extensive getting started guide which can be found on the ISY994 component page.
# Example configuration.yaml entry
isy994:
Logbook ![](upload://3jyEZCMwaQtu3pGKWFqkAwmmcIE.png) I (Paulus) have added a logbook component. The logbook component provides a different perspective on the history of your house by showing all the changes that happened to your house in chronological order. See the demo for a live example.
logbook:
Transmission support ![](upload://xCTC2SZd9T5ZtpWfaxUtGxLa0db.png) James has also contributed support for integrating Transmission into Home Assistant.
  platform: transmission
  host: 192.168.1.26
  port: 9091
  username: YOUR_USERNAME
  password: YOUR_PASSWORD
  monitored_variables:
    - type: 'current_status'
    - type: 'download_speed'
    - type: 'upload_speed'
Modbus support Kixam has contributed support for modbus, a serial communication protocol to control PLCs. It currently supports sensors and switches which can be controlled over serial, TCP and UDP connections.
modbus:
  type: serial
  method: rtu
  port: /dev/ttyUSB0
  baudrate: 9600
  stopbits: 1
  bytesize: 8
  parity: N
  platform: modbus
  slave: 1
  registers:
    16:
      name: My integer sensor
        unit: C
    24:
      bits:
        0:
          name: My boolean sensor
        2:
          name: My other boolean sensor
switch:
  platform: modbus
  slave: 1
  registers:
    24:
      bits:
        0:
        2:
          name: My other switch
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2015/04/25/release-notes/
