A new version of Home Assistant has just been pushed out. It contains bugfixes contributed by jamespcole, andythigpen, trainman419 and me. It also adds a bunch of great new features:
Script
Andythigpen has contributed a script component. This allows users to create a sequence of service calls and delays. Scripts can be started using the service script/turn_on
and interrupted using the service script/turn_off
. A separate page has been added to the frontend to see the status of your scripts.
# Example configuration.yaml entry
script:
# Turns on the bedroom lights and then the living room lights 1 minute later
wakeup:
alias: Wake Up
sequence:
- alias: Bedroom lights on
execute_service: light.turn_on
service_data:
entity_id: group.bedroom
- delay:
# supports seconds, milliseconds, minutes, hours, etc.
minutes: 1
- alias: Living room lights on
service_data:
entity_id: group.living_room
Scene I (Paulus) have contributed a scene component. A user can create scenes that capture the states you want certain entities to be. For example a scene can contain that light A should be turned on and light B should be bright red. Deactivating a scene will restore the previous state from before the scene was activated. Just like scripts, scenes have their own separate page to see which scenes are on.
scene:
- name: Romantic
entities:
light.tv_back_light: on
light.ceiling:
state: on
color: [0.33, 0.66]
brightness: 200
SABnzbd ![](upload://fmAHK8psqP57Bm6QqNkCY5QfWC.png) James Cole has contributed support to integrate SABnzbd. This will allow you to monitor your downloads from within Home Assistant and setup automation based on the information.
- platform: sabnzbd
api_key: YOUR_API_KEY
# Example: http://192.168.1.32:8124/
base_url: YOUR_SABNZBD_BASE_URL
monitored_variables:
- type: 'current_status'
- type: 'speed'
- type: 'queue_size'
- type: 'queue_remaining'
- type: 'disk_size'
- type: 'disk_free'
PushOver ![](upload://vdBbHNFH902RkkhxKEqO05lsIY.png) James Cole has also contributed support for the PushOver service as a platform for the notify component. This allows components to send messages to the user using PushOver.
notify:
platform: pushover
# Get this by registering a new application on https://pushover.net
api_key: ABCDEFGHJKLMNOPQRSTUVXYZ
# Get this by logging into your account on https://pushover.net
user_key: ABCDEFGHJKLMNOPQRSTUVXYZ
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2015/03/22/release-notes/
