Add-on: SSH 2.7
- Support new home-assistant config check api call
- Update CLI output
Add-on: SSH 2.7
Hass.io 0.58
The new network layer allow now to communicate inside hassio network with every addon with hostname or docker name of that addon. Also all addon can use homeassistant
that resolve to homeassistant instance. You can also use the add-on names inside homeassistant configuration. More feature, based on that will follow soon. All internal containers like supervisor have now a fix IP on that network and prevent problems with other custom docker stuff on host.
You need restart a add-on to use the internal network. If you run into a problem after update, please reboot the host.
Add-on GIT_pull 1.0 / 1.1:
Add-on nginx_proxy 0.6:
Add-on nginx_proxy 0.7:
Hass.io 0.61:
boot
) on startupAdd-on ssh 2.8:
Hass.io 0.62:
int(min, max)
and float(min, max)
match
to allow use regex: match(^(?:man|woman)$)
Hass.io hardware image 1.1:
The new OTA updater support background update Task. The previous updater stop all dockers until the OTA update was donw. Now we have only downtime for the reboot. But for the update from 1.0 to 1.1 it run with old OTA updater. That need some time, so don’t worry and wait until the device have reboot.
Hass.io 0.64:
config.json
Add-on Configurator 0.2.0:
Add-on DuckDNS 1.0:
Add-on Dnsmasq 1.0:
Hass.io 0.65:
gpio
to map /sys/class/gpio
io.hass.name
, io.hass.description
, io.hass.url
