Catch-all topic for release notes related to the Hass.io platform.
Home Assistant 0.44.1
- Fixes bug with hass.io panel crashing when trying to view info on a not installed add-on.
Home Assistant 0.44.2
- (Now it should work) Fixes bug with hass.io panel crashing when trying to view info on a not installed add-on.
Hass.IO 0.22
- Add url to addon config
- Add UI change for API - HomeAssistant 0.44.x
Hass.IO 0.23
- Add watchdog for homeassistant container
- Cleanup task code
- Add support for arch on addons
- Add support for restart homeassistant with
/homeassistant/restart
- Add support for restart add-on with
/addons/{addon}/restart
Hass.IO 0.24
- Security API with password and TOTP support
- Local repository build now add-on local if no
is set - Fix HomeAssistant watchdog
Hass.IO 0.25
- Add
build
to addons api - Better add-on data layer handling
- Fix wrong version in installed addons
- Fix start not running add-on after update
Hass.IO 0.26
- Add panel for homeassistant 0.45
- Allow local build for all addon repository types
- Fix output of invalid options for homeassistant 0.45
Hass.IO 0.27
- Change docker meta data from ENV to LABEL
ENV VERSION
is now deprecated - Allow to use docker cache on our build system
Hass.IO 0.28
- Add docker device support with
devices
addon config option - Maps are now default read only. For rw access use
map: ["config:rw"]
Important
- Please update all core add-ons to latest after update
- If you core add-on is older than 1 version behind, please copy past options and reinstall this core add-on to avoid problem with last change on 0.26
Hass.IO 0.29
- Allow to mount host /mnt for external device into add-ons with
mnt
map options - Add new map
share
for add-ons and homeassistant/share
- Add new option
environment
to add-on config to manipulate env of add-on
Hass.IO 0.30
- Remove
mnt
from map options. This can allow to brake our resinos systems from a add-in.
How to map external storage:
https://home-assistant.io/hassio/external_storage/
Hass.IO Image 0.8
- Cleanup yocto layer
- HostControll support change of hostname
- ResinOS pump to 2.0.3
Warning:
After you start the OTA update, don’t poweroff until system is reboot! While update ist running, alls services are down.
HomeAssistant Docker 0.45
- Hass.IO stream UI now direct to HomeAssistant for fast deployment
- Add support for SQL Database connection
- Add OpenAlpr and OpenCV support
We work an a new Cache System to fast Update HomeAssistant. At the moment it can take 5-15min for the Update. After that we shoudl be able to use the local cache for faster updates.
Hass.IO 0.32
- Allow add-on to run on host netzwork
host_network: true
- Add API support for change hostname on UI
- Add timezone support for homeassitant/addons with supervisor API.
The new core add-ons and homeassistant > 0.45.0 should support the new timezone API. Until UI support for timezone selection is done, you can use:
curl -d '{"timezone": "Europe/Zurich"}' http://hassio.local:8123/api/hassio/supervisor/options
After update you can run into a cache problem. Try CTR-F5 to reload the page cache and all work fine.
HomeAssistant Docker 0.45.1
- Fix panel load error if homeassistant http password is set
- Add support for new timezone support with hass.io 0.32
For update:
- Disable password and update it on UI
- Use curl and call the API manual with:
curl -H "x-ha-access: YOUR_PASSWORD" -d '{"version": "0.45.1"}' http://hassio.local:8123/api/hassio/homeassistant/update
